High pressure oil leak
Old 02-17-2012, 05:50 PM
jerkypants's Avatar
jerkypants
jerkypants is offline
Well the saga continues...
I pick up my truck, drive it 60 miles, it runs like a champ as usual, I park it shut it off, turned the key and it started. A little hard, but it started. Why?
Thank you m-chan, I really am genuine when I say I mean no foul. Where ever you are a master, I hope they appreciate you. I would love for you to look at my truck.
  #32
Old 02-17-2012, 05:58 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Cause you still have a HPO Leak
It will only get worse from here on out
I would get that STC Fitting changed ASAP you dont want it to Blow out and crack the rear cover of the moter
You will really be having a BAD Day then if that rear cover gets cracked then the Moter is coming out
  #33
Old 02-17-2012, 06:08 PM
jerkypants's Avatar
jerkypants
Okay, Thank you
I was just wondering cause they say it wont start hot.
  #34
Old 02-17-2012, 06:11 PM
bpounds's Avatar
bpounds
bpounds is offline
Like any seal leak, it can vary in volume as the seal material moves around under pressure and vibration.
  #35
Old 02-17-2012, 06:18 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Okay, Thank you
Hot Oil is thinner vicosity so if you have a leak the Hot Oil just runns out to Fast and cant build the pressure to start
  #36
Old 02-17-2012, 06:51 PM
John Irwin's Avatar
John Irwin
John Irwin is offline
If I can interject into a master techs explanation, do yourself a favor and get a 12mm gear wrench for the 2 valve cover bolts under the hvac. Your quality of life will be greatly improved.
  #37
Old 12-02-2013, 08:41 AM
LFDL5's Avatar
LFDL5
LFDL5 is offline
Hi all,
My truck has a high pressure oil leak. Ford wants 200 more to tell where it is.
Fix it myself or ford?
Any roughs on cost?
Easy or hard to fix...depending?
Did you find a reliable shop? I am having the same problem in the S.NH area?
  #38
Old 12-02-2013, 04:41 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
It might help to go to your state FTE chapter and ask for suggestions. You might even be able to find a good dealership to help you.
New Hampshire Chapter - Ford Truck Enthusiasts Forums
  #39
Old 12-02-2013, 05:41 PM
LFDL5's Avatar
LFDL5
LFDL5 is offline
Thank you. Since that post I have looked into a shops mentioned several times on FTE and confirmed from other sources that it was a top notch recommendation. My truck is going to MassDiesel on Tuesday. Will post on experience when complete
makuloco2000
1999 to 2016 Super Duty
08-31-2014 05:26 PM
fomoconut
11-01-2010 09:15 PM
cardinal thunder
09-29-2010 12:01 PM
FORD MEGA CAB!!!
06-27-2008 07:38 PM
traxdude
05-24-2000 04:27 AM
Quick Reply: High pressure oil leak
