300 6 cylinder in a 1953-56 f100 ??
  #31
Old 02-19-2012, 05:57 PM
55 f350's Avatar
55 f350
55 f350 is offline
yep that's the one !!!! i like big a-- blowers poking through the hood myself , although on a six might look a lil' odd .... the black one is way cool too ! are those webers , delortos what ? they look cool on that 300 . you know that green bomb has got to freak some people out . quite , no lumpy cam , and open the hood and ............
  #32
Old 02-19-2012, 06:09 PM
fordman75's Avatar
fordman75
fordman75 is offline
The big 6-71 or 8-71 blowers are a little on the big side for a 300!
Yea I believe the carbs on the black one are Weber IDA's. I use to have a brand new set of triple side draft Weber DCOE's for a 300 a few years back. But I never got to run them.
Being a little bit of a sleeper is cool. But I still prefer the nasty sounding lumpy cam! This vid is my favorite.
68 ford 240 300 6 cylinder clay smith cam - YouTube
  #33
Old 02-20-2012, 07:59 PM
55 f350's Avatar
55 f350
55 f350 is offline
dude that thing sounds freaking NASTY !!!!!!!!!! oh i loved that !!!!!!!!! coulda sworn i was listening to a v-8 !!!!! da--it i think im gonna be looking for a 300 again and find a project beater truck for it !!!!!!!! sheezuz that thing is NASTY !!!!!!!!!!!
  #34
Old 02-20-2012, 08:06 PM
fordman75's Avatar
fordman75
I love the sound of it too. Which kind of bums me out. I wanted to run a similar cam. But I have to run a different cam profile then that with the supercharger. I guess I'll just have to live with the blower whine instead.
  #35
Old 02-20-2012, 08:26 PM
55 f350's Avatar
55 f350
55 f350 is offline
aww poor you !!!!!!! a blower whine to replace the lumpy cam ........ LUCKY SO'N'SO !!!!!!!!! you know what the cure is doncha ???????? buy a beater old ford 1/2 ton from the late 60's to late 70's and build one like that then you got the best of both worlds !!!!!!!!!!!!!!!!!!!!! i wish my flattie's or my 4.6 could sound like that , or be fortunate enough too build a supercharged anything now !!!!!!! { i'm too "tight" to spend the money !!!! LOL !!!!!!! }
  #36
Old 02-20-2012, 08:36 PM
fordman75's Avatar
fordman75
I've got too many vehicles the way it is!! I really don't need more projects.
I'm so broke that supercharged engine will probably take me 5 years if not longer to get built.
  #37
Old 02-21-2012, 02:48 AM
55 f350's Avatar
55 f350
55 f350 is offline
i ain't broke , but in these times it's so hard to convince myself to let go of the cash , and in the case of the engines i have available , 3 flatheads , a y block , and a 4.6 , i seem to have chosen the most expensive starting points ford has in the case of prices . i still cant get that 68 you posted outta my head ...
  #38
Old 02-21-2012, 08:08 AM
fordman75's Avatar
fordman75
Hey I dumped a good running 400 and then a strong running modified 351W to run a big 6 in my 54!!
I'm also considering building a 240 instead of the 300! That would be even more embarrassing for the poor sap with a V8. Not only did he get whooped by a inline 6 but it was a little 240!!
The 240 is basically the same engine as the 300 just different rotating assembly and the head has 68cc combustion chambers instead of the carbed 300's 76cc chambers. Because of the 240's shorter stroke it has a stronger crank. And with just some good rod bolts the 240 can easily handle 7,000 rpms!
  #39
Old 02-21-2012, 08:18 AM
55 f350's Avatar
55 f350
55 f350 is offline
i would love to see it embarass some late model sheopl-mobile !!!!!!!!!
  #40
Old 02-24-2012, 04:26 PM
taylor90's Avatar
taylor90
taylor90 is offline
Hello, i have a 223 inline 6 in a 56 f100. I am currently looking for a harmonic balancer for it, since mine is shot. I dont know if the 215 and 223 are similar but would you be interested in letting your harmonic balancer go if it were the same ?
  #41
Old 02-24-2012, 05:18 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I might have a whole 223 if you're interested. Good runner. I just got a sm 465 tranny for my cummins and am getting ready for the swap. Of course it depends where you are located...
  #42
Old 02-24-2012, 05:26 PM
taylor90's Avatar
taylor90
taylor90 is offline
I just rebuilt my 223. What year is the engine you are talking about. Just out of curiosity, does it run one or two belts. I am located in Louisiana.
  #43
Old 02-24-2012, 08:08 PM
Michigan Rick's Avatar
Michigan Rick
Michigan Rick is offline
search out the 56 panel with Punctual Plumber on the side.....was in Classic Trucks magazine a few years back and had a 300 six in it and some pics in the article..
only 300 six pics I know about....
  #44
Old 02-09-2016, 11:22 PM
joeplouff's Avatar
joeplouff
joeplouff is offline
55 f350
Did you have any clearance issues I plan to eventually put one in my 55 f350 that I am getting next week. As of right now it has the 223, figured I would step it up a little and put a 300 in it?
Originally Posted by skipr
I put a 300 in my 49 f2 Just love it. not a hard install. let me know if you have any questions
  #45
Old 02-10-2016, 12:29 AM
fordman75's Avatar
fordman75
In a 53-56 the only real clearance issue with a 300 6cyl is an engine driven cooling fan will hit the front frame crossmember under the radiator/core support. So to get around that requires an electric cooling fan. Unless you've got access to a high mount industrial 240/300 cooling fan set up. This set up actually has a fan mount on the thermostat housing. I have one of these fan set ups in my storage unit but am missing the water pump pulley.
Here's a picture of my 54 when I started to tear it down. It had a 300 swapped into it when I bought it.
Quick Reply: 300 6 cylinder in a 1953-56 f100 ??
