Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 02-16-2012, 08:08 AM
jniolon's Avatar
jniolon jniolon is offline
1953 Ford F-100
jniolon has a very good reputation on FTE.jniolon has a very good reputation on FTE.jniolon has a very good reputation on FTE.
'53 F-100 AC PROB.. CONDENSER TOO FAT
Hi guys.. I'm John and I live in the 48-56 forum... I'm building a '53 and have incorporated a major blunder in the build. The truck is 3/4 finished with frame painted and 9/10s of body work done. I'm using a Fairlane tilt hood..
I'm using a custom alum. radiator in front of a 460 with puller fan and condenser for A/C mounted on front of radiator. Since the air deflector is part of the hood we had to fab up radiator mounts.. much like drag car mounts with stubs welded to frame cross member and radiator mounted to tubes that slide over stubs. When we fabbed up the radiator mounts we fitted it close to the engine but the hood wasn't in place... (see where I'm going ??)
Remounted hood and the air deflector hits the condenser. I can gain a little room here and there but I'm afraid not enough...which will mean moving engine back... cutting out mounts and transmount and it's all pretty and painted...
I'm wondering about remove condensers w/fan... I can probably find room under cab or bed... but wondering how efficient they are and if I'll get adequate cooling from the a/c...
anyone got any experience with remotes and can give me the 411 ??? problems, advantages (if any)... other solutions...
If I can't find the extra room it's gonna be a major setback in this project... so I'm looking for miracle solutions..
thanks
John
__________________
'53 f-100
  #2 (permalink)
Old 02-22-2012, 06:53 AM
critterf1's Avatar
critterf1 critterf1 is offline
Garage is empty, add now
critterf1 is gaining momentum as a positive member of FTE.critterf1 is gaining momentum as a positive member of FTE.
Condenser needs to be in "direct" airflow or will cause "high" head pressures. You should be able to figure out some way to make it fit.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 02-24-2012, 11:24 AM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
Are you using an aftermarket comdenser? I know some can be as thick as OEM models at about 1.5" thick and others as thin as newer OEM stuff at about 0.75" thick.
The 3/4" thick models are as thin as they get. There are many sizes available, 14x20, 13x 24, etc
  #4 (permalink)
Old 02-24-2012, 12:15 PM
jniolon's Avatar
1953 Ford F-100
Here's what I've got... it's the thinner one... and it's spaced about 3/4" in front of the radiator... I can squeeze a little there maybe... gonna get the engine back soon and I'll know how bad my blunder really was...
john
__________________
'53 f-100
Tags
100, 53, body, f100, fatford, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
