96 F-250 Powerstroke leaking fuel - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-15-2012, 10:53 PM
Sam Thomas Sam Thomas is offline
Sam Thomas is starting off with a positive reputation.
i own a 96 f-250 powerstroke which is leaking fuel i am only 15 and dont know a whole lot about diesel trucks...the fuel is leaking at the top of the engine and running down the back where it drips onto the ground...i was directed here by my shop teacher who said you guys know it all so i was hoping someone had an idea of where it was leaking
Old 02-15-2012, 11:03 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Welcome to FTE!
It could be a few things fuel bowl cracked, bad fuel lines, bad fuel pump, leaking sensor. The best thing to do is clean it real good start the truck and see if you can see where it's leaking
Old 02-15-2012, 11:16 PM
alright sounds great thanks a lot for the advise!
Old 02-15-2012, 11:29 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Its probably those little rubber fuel hoses behind and down from the fuel bowl. Clean it all up then start it and use a small mirror to look around.
Old 02-16-2012, 07:21 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
welcome to FTE.
once you find the leak, if you can take a few pictures showing where the leak is to show us it will be easier than trying to describe where the leak is.
also tell your shop teacher thanks for the recommendation!
Old 02-16-2012, 08:05 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
No doubt your shop teacher is a smart guy!
Welcome to FTE!
clean it up the best you can and follow theds from the posts up there ^
Stick around and really get to know your truck!
Old 02-16-2012, 10:13 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Talking
Quote:
Welcome to FTE!
X3 about your shop teacher and one more for the WELCOME aboard
Maybe you are one of the youngest in the forum IDK.
BTW, Ian why you didnt give him your links you have about the PSD?
Old 02-16-2012, 10:41 AM
Copedawg's Avatar
Old 02-16-2012, 11:27 AM
RÖENTGEEP's Avatar
FOREIGN GURU
Wink
Old 02-16-2012, 12:18 PM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
Quote:
I second what Glenn said.. I just completed putting new lines between the fuel pump and bowl because of the fuel leak. The valley would fill up and leak off the back of the engine. I unbolted the Fuel Bowl, not the pump to move it around to install the new lines. A person can accidentally drop that tappet under the fuel pump into the engine!
Fuel leaking, 1997 F250 CT 1994.5 - 1997 7.3L Power Stroke Diesel 1 10-01-2014 02:21 PM
Shifting Problem Under WOT f2504x4man 1994.5 - 1997 7.3L Power Stroke Diesel 14 07-17-2013 05:00 PM
7.3L powerstroke left me stranded - fuel issue? Fordownsall 1994.5 - 1997 7.3L Power Stroke Diesel 17 06-23-2013 01:26 PM
ICP sensor 7117 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-30-2011 01:18 AM
96 f250 4x4 powerstroke trans interchange mirage5058 1994.5 - 1997 7.3L Power Stroke Diesel 8 01-10-2011 10:26 AM
Tags
1997, 250, 73, 96, f250, ford, fuel, leak, leaking, mirrors, parts, powerstroke, powrestroke, system, valley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
