6.4 no power and no boost - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 02-15-2012, 09:49 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
So cruising down the I-15 today with about a small excavator on the goose-neck the truck falls on its face. The boost goes to zero than the monitor pressure actual reads -3.5 on the dashdaq. After pumping the pedal a little the boost comes back flutters than drops off again, i pull over and check it out. I ran a Diag with the dash-daq and pulled up a P0106 code( manifold Absolute pressure/baro sensor range/performance) and P1000 (OBD readiness test not complete) Cleared the codes took off again and the same problem. No black smoke trying to take off or when the boost drops to zero. Truck seems to go into limp mode. I managed to limp home on some side streets which is no treat with that much weight. No CEL or MIL lights. I went by the dealer and picked up a map sensor and the IAT next to it just in case since they close at 7:00.
Any thoughts?
Old 02-16-2012, 12:04 AM
Well pulled her in the garage and dug in, looks like the map sensor was the culprit, it got plugged up with soot and oily residue. Even after the EGR system was dumped and the CCV was cleaned I'm still being haunted by these little gremlins. I went ahead and change the IAT 2 while i was in there.
Wow must have been messing up for awhile truck is alot more responsive. No code good to go, thats been the easiest fix so far......lol
Old 02-16-2012, 06:19 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
interesting. It is a wonder more of us don't have a problem.
this summer when it warms up I am pulling my cac hoses to see how much buildup I have.
I have never had mine off.
Old 06-17-2014, 08:38 PM
ahook168 ahook168 is offline
ahook168 is starting off with a positive reputation.
My truck just did the same thing pulling my 5th wheel through the hills in VA. Thought I had tripped some safety feature because I was pushing pretty hard. It did it again two night later without a load. SANDDEMON, Have you had any more issues since you did this work? I am about to go get these sensors and I just want to make sure before doing so. Thanks
Old 06-18-2014, 10:11 AM
Quote:
No i havent had any issue's since i changed them, but i have had my egr system removed since then.
Hard Start/No Start – Hot or Cold '04F250SuperDuty 6.0L Power Stroke Diesel 27 04-17-2016 08:59 AM
2011 F350/Issues..Turbo/Smells/Shutter/Death Wobble/Transmission/…with VIDEO!! Big-Sarge 6.7L Power Stroke Diesel 45 06-19-2015 01:06 AM
Sold fordjunkyNC Ford Truck Parts for Sale 0 10-03-2014 12:07 AM
White Smoke, No Power - Cold AND Hot trippn4re 1999 - 2003 7.3L Power Stroke Diesel 23 06-02-2014 05:16 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Tags
64, article, boost, cel, codes, company, dashboard, diesel, egr, ford, limited, power, powered, revs, southwest, stroke, trading
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
