2008 6.4 powerstroke won't start
getting code p0231 sounds electrical . ford wants to replace high pressure pump for 4300$ they also just did all the rockers so maybe they chaffed a wire and are lying to us.. also a question about replacing inertia switch i read was a problem on one persons truck doing p0231 ? any ideals
also truck was doing 65 on hwy and just died as if out of fuel. truck will not fire with WD 40. i was told not to use starter fluid but if it does not kick its electrical
P0231 refers to the low pressure fuel pump, the one in the HFCM on the frame rail, not the high pressure fuel pump. If they are misdiagnosing this that badly I'd get my truck out of there ASAP.
P0231 - Fuel Pump Secondary Circuit Low
Description: The powertrain control module (PCM) monitors the fuel pump monitor (FPM) circuit. The test fails if the PCM commands the fuel pump ON and B+ voltage is not detected on the FPM circuit.
Possible Causes: Inertia fuel shutoff (IFS) switch
Fuel pump relay
FP circuit open in the harness
FP circuit short to voltage in the harness
Diagnostic Aids: Disregard a secondary fuel pump circuit DTC P0231 at this time and diagnose fuel pump control circuit DTCs P0627 or P0629 (if present). DTC P0231 may be set as the result of the FP circuit concern.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test MA .
MA: Fuel Pump Control - Low Pressure Pump MA: Introduction
MA1 PRELIMINARY DIAGNOSIS FOR DIAGNOSTIC TROUBLE CODES (DTCS) P0231, P0232, P0627, P0628 OR P0629
Retrieve and record all DTCs.
Access the freeze frame data (if available) and record the DTC conditions.
Clear the DTCs.
Carry out the KOEO and KOER self-test.
Are any DTCs present?
Yes No
For DTCs P0627, P0628 and P0629, GO to MA2 .
For DTC P0231, GO to MA7 .
For DTC P0232, GO to MA13 . GO to MA2 .
MA2 CHECK VPWR AT THE FUEL PUMP RELAY
Key in OFF position.
FP Relay connector disconnected.
Key ON, engine OFF.
Measure the voltage between:
( + ) FP Relay Connector, Harness Side ( - )
VPWR - Pin 86 Ground
Is the voltage greater than 10 V?
Yes No
GO to MA3 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA3 CHECK THE FUEL PUMP RELAY
Carry out the fuel pump relay component test. Refer to the Wiring Diagrams Cell 149 Component Testing.
Is a concern present?
Yes No
INSTALL a new FP relay. CLEAR the DTCs. REPEAT the self-test. GO to MA4 .
MA4 CHECK THE FP CIRCUIT FOR AN OPEN IN THE HARNESS
PCM-B connector disconnected.
Measure the resistance between:
( + ) FP Relay Connector, Harness Side ( - ) PCM-B Connector, Harness Side
FP - Pin 85 FP - Pin 56
Is the resistance less than 5 ohms?
Yes No
GO to MA5 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA5 CHECK THE FP CIRCUIT FOR A SHORT TO VOLTAGE IN THE HARNESS
Key ON, engine OFF.
( + ) PCM-B Connector, Harness Side ( - )
FP - Pin 56 Ground
Is any voltage present?
Yes No
REPAIR the short circuit. CLEAR the DTCs. REPEAT the self-test. GO to MA6 .
MA6 CHECK THE FP CIRCUIT FOR A SHORT TO GROUND IN THE HARNESS
FP - Pin 56 Ground
Is the resistance greater than 10K ohms?
Yes No
GO to MA19 . REPAIR the short circuit. CLEAR the DTCs. REPEAT the self-test.
MA7 DTC P0231: CHECK THE INTERNAL RESISTANCE OF THE IFS SWITCH
Note: DTC P0231 may be set as a result of a FP circuit concern. Disregard a secondary fuel pump circuit DTC P0231 at this time and diagnose fuel pump control circuit DTCs P0627 or P0629 (if present).
Note: Verify the inertia fuel shutoff (IFS) switch is set (button pushed in). Refer to the Owner's Literature for location.
IFS Switch connector disconnected.
( + ) IFS Switch Connector, Component Side ( - ) IFS Switch Connector, Component Side
B+ - Pin 2 IS - Pin 1
Yes No
GO to MA8 . INSTALL a new IFS switch. REFER to the Workshop Manual Section 301-01, Fuel Tank And Lines.
MA8 CHECK THE FUEL PUMP VOLTAGE
Key ON, engine OFF.
( + ) IFS Switch Connector, Harness Side ( - )
B+ - Pin 2 Ground
Is the voltage greater than 10 V for approximately 30 seconds?
Yes No
GO to MA12 . GO to MA9 .
MA9 CHECK THE FUEL PUMP VOLTAGE CIRCUIT FOR AN OPEN
( + ) IFS Switch Connector, Harness Side ( - ) FP Relay Connector, Harness Side
B+ - Pin 2 FPPWR - Pin 87
Yes No
GO to MA10 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA10 CHECK VPWR AT THE FUEL PUMP RELAY
Key ON, engine OFF.
B+ - Pin 30 Ground
Are the voltages greater than 10 V?
Yes No
GO to MA11 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA11 CHECK THE FUEL PUMP RELAY
Yes No
INSTALL a new FP relay. CLEAR the DTCs. REPEAT the self-test. GO to MA12 .
MA12 CHECK THE FP CIRCUIT FOR AN OPEN IN THE HARNESS
( + ) PCM-B Connector, Harness Side ( - ) FP Relay Connector, Harness Side
FP - Pin 56 FP - Pin 85
Yes No
GO to MA19 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA13 DTC P0232: CHECK THE FUEL PUMP
Note: DTC P0232 may be set as a result of a FP circuit concern. Disregard a secondary fuel pump circuit DTC P0232 at this time and diagnose fuel pump control circuit DTC P0628 (if present).
Key ON, engine OFF.
Is the fuel pump on?
Yes No
GO to MA14 . GO to MA15 .
MA14 CHECK THE FPM CIRCUIT FOR A SHORT TO VOLTAGE IN THE HARNESS
FP connector disconnected.
Key ON, engine OFF.
FPM - Pin 15 Ground
Yes No
REPAIR the short circuit. CLEAR the DTCs. REPEAT the self-test. GO to MA19 .
MA15 CHECK THE FPM CIRCUIT FOR AN OPEN IN THE HARNESS
( + ) PCM-B Connector, Harness Side ( - ) FP Connector, Harness Side
FPM - Pin 15 FPPWR - Pin 1
Yes No
GO to MA16 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA16 CHECK THE FUEL PUMP GROUND FOR AN OPEN IN HARNESS
( + ) FP Connector, Harness Side ( - )
FPGND - Pin 2 Ground
Yes No
GO to MA17 . REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test.
MA17 CHECK THE FUEL PUMP RESISTANCE
( + ) FP Connector, Component Side ( - ) FP Connector, Component Side
FPPWR - Pin 1 FPGND - Pin 2
Yes No
GO to MA18 . INSTALL a new FP. REFER to the Workshop Manual Section 303-04, Fuel Charging and Controls.
MA18 CHECK THE FUEL PUMP RELAY
Yes No
INSTALL a new FP relay. CLEAR the DTCs. REPEAT the self-test. GO to MA19 .
MA19 CHECK FOR CORRECT PCM OPERATION
Disconnect all the PCM connectors.
Visually inspect for:
pushed out pins
corrosion
Connect all the PCM connectors and make sure they seat correctly.
Carry out the PCM self-test and verify the concern is still present.
Is the concern still present?
Yes No
INSTALL a new PCM. REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) . The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector.
Fuel pump relay
Clear the DTCs.
Yes No
Key ON, engine OFF.
Yes No
Yes No
Yes No
Key ON, engine OFF.
FP - Pin 56 Ground
Yes No
FP - Pin 56 Ground
Yes No
Yes No
Key ON, engine OFF.
B+ - Pin 2 Ground
Yes No
Yes No
Key ON, engine OFF.
B+ - Pin 30 Ground
Yes No
Yes No
Yes No
Key ON, engine OFF.
Yes No
Key ON, engine OFF.
FPM - Pin 15 Ground
Yes No
Yes No
Yes No
Yes No
Yes No
pushed out pins
corrosion
Yes No
vzfiostech2
12-07-2019 03:58 PM
mcguirkp
03-28-2017 09:00 AM
KENCOEXT
01-13-2004 08:08 AM
