Power windows and 4wheel drive switch not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-15-2012, 09:30 PM
CWO-06250's Avatar
CWO-06250 CWO-06250 is offline
CWO-06250 is starting off with a positive reputation.
On my 03 Super Duty crew cab 6.0 4x4 my windows do not work and the 4 wheel drive switch do nothing. They were all working one day then I let someone borrow the truck for the weekend and then they have not worked since.
SYMPTOMS
Driver door
when closed the door lock switch will work fine and the window switch lights will light up.
No windows will roll down but the driver front switch will make a buzzing sound.
Door courtesy light is dim all the time but when I hit a window switch it will get bright.
Open the door and nothing works, no switch lights, no door light, no door locks.
Passenger front door
Door lock switch always works
window switch nothing
open door and no change lock switch still works.
Rear doors are the same as passenger.
I have swapped out the switches from my 06 and have the same problems also swapped out fuse/breaker no change.
I am getting almost 12 volts through the ground wire to the switches and light.
Old 02-15-2012, 11:55 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
You have a bad ground.
Old 02-16-2012, 09:59 AM
CWO-06250's Avatar
I figured that but by bad ground you mean?
Does it sound to be broken? I am lost on how 12 volts can be put into the ground system without blowing fuses or causing major problems. This problem has been going on for about 6 months now.
Old 02-16-2012, 12:27 PM
dennis350 dennis350 is offline
dennis350 is starting off with a positive reputation.
Your lights in all the door switches have their own ground and all 4 of the window motors have a common ground in the drivers side door, they need to all come back there to give you control of all windows. There should be 2 black wires in there, one for the lights on that side and one for all the window motors, not sure its terminated in there so you may need to trace it. I don’t see the 4 wheel drive switch in that circuit so I think it’s a second issue.
All dc circuits must complete the loop between positive to ground to work meaning on your battery.
Old 02-16-2012, 04:46 PM
CWO-06250's Avatar
I figured out the 4wheel drive and that was unrelated. Thanks for the info on the ground, I will look into it and see what I come up with.
I have checked the black wire that is coming up to my window switch controls that my book says should be a ground and it has 12 volts and the coming from the switch nothing until I turn the key on then from the switch side it is giving 12 volts as well to the black wire, So when disconected and the key on I am getting power from both sides of the ground wire.
Also noticed that the passenger door curtousy light is working fine.
Old 02-16-2012, 04:47 PM
CWO-06250's Avatar
The 4 wheel drive was from having my trans replaced a few months back the tranny guy broke the clip that holds the plug into the transfer case so it wont stay in long enough to work the 4wheel. Why does everything have to be electronic now days.
2000 Crew Cab Drivers Side Door Lock Question stowbilly96 1999 to 2016 Super Duty 3 11-09-2016 01:47 PM
Door locks interm. Fordtough2006 6.0L Power Stroke Diesel 0 02-24-2016 02:07 PM
Power windows & door locks have suddenly quit working mrjimbov Electrical Systems/Wiring 7 11-23-2014 08:20 AM
Passenger Window Problem? Eric White Excursion - King of SUVs 1 06-27-2012 01:47 PM
Door Switches Doing a Crazy Thing!! JHadds Excursion - King of SUVs 3 11-18-2011 02:00 PM
Tags
1999, drive, duty, ford, passenger, power, ranger, super, truck, wheel, window, windows, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
