diesel stalls when tires spin - Page 2 - Ford Truck Enthusiasts Forums
Old 02-16-2012, 02:15 AM
Roasted7's Avatar
Roasted7 Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
If you hit the same rpm without spining the tires, does it still stall?
Might want to check fuel pressure while someone smashes the throttle down.
Is your air cleaner clogged?
Old 02-16-2012, 04:15 AM
kornfanjoe's Avatar
kornfanjoe kornfanjoe is offline
kornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant future
No it seems to be only when the tires spin. I will have to see about testing the fuel pressure but it runs great in any other conditions. Air filter is a little dirty but not plugged and the vacuum indicator is not tripping.
Old 02-16-2012, 07:10 AM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
I remember a post of a guy snowplowing, having a similar problem, the engine would stall when pushing a load of snow...
Old 02-16-2012, 07:56 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The PCM will reduce fueling at 4000 rpm's, but sounds like there is something else going on.
A/C compressor spins after engine shut off broncoholic 1997-2006 Expedition & Navigator 30 06-25-2016 08:11 PM
Truck shuts off when I lose traction BigBlackF-250 1999 - 2003 7.3L Power Stroke Diesel 2 01-22-2016 07:03 AM
Truck ****s off when I lose traction BigBlackF-250 1999 - 2003 7.3L Power Stroke Diesel 1 01-21-2016 08:55 PM
Truck shutting down on me. Mango11b 2004 - 2008 F150 7 12-24-2014 07:00 PM
What does this mean.............tires spin in neutral when jacked up wolfrace 1999 - 2003 7.3L Power Stroke Diesel 6 04-28-2010 12:44 AM
Tags
60, 60l, diesel, f250, gridlock, news, politics, powered, recent, shuts, spin, spinning, stalls, tires, truck, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
