'05 Rear oil change - any gasket?
Old 02-15-2012, 07:16 PM
fishintheobx's Avatar
fishintheobx
fishintheobx is offline
Question '05 Rear oil change - any gasket?
Okay...my rear has been chattering on some turns lately, figured the LSD clutches may be a little thirsty for the additive. So I got my Amsoil guy to fix me up with their Synthetic 75w-140 Oil. Even got the Friction Modifier Additive.
There seems to be a good walk-through of the process here: Welcome to guzzle's Rear Differential Maintenance Web Page
For anyone that has done this, was there a gasket on your diff cover? I've heard no, instructions say no, but read a guide elsewhere to advises placing the sealant on the gasket also. HUH!?
The Drinker: 2005 Ford Excursion / 4x4 / 6.0 Powerstroke - 18 MPG
The Miser: 2010 VW Jetta Sportwagen / 2.0 TDi - 42 MPG
The Moneypit: 2002 Glacier Bay 240 Center Console - Twin Yamaha - Runs on Gas, not "thanks".
Old 02-15-2012, 08:24 PM
EXv10's Avatar
EXv10
EXv10 is offline
Most don't use a gasket now days including this one.
Old 02-15-2012, 08:26 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
No gasket, use good gasket sealer.
Old 02-15-2012, 09:33 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
By gasket sealer, they mean RTV....
Old 02-15-2012, 09:35 PM
Sader's Avatar
Sader
Sader is offline
I use Permatex Ultra Black. Been using this on differential covers for years with excellent results.
Cheers
Old 02-15-2012, 09:44 PM
Skinsfan6's Avatar
Skinsfan6
Skinsfan6 is offline
Grey silicone was used from the factory. I used a felpro gasket from the auto parts store when I reinstalled mine last time because I'm impatient and hate letting rtv set up before torquing it down. No leaks yet.
Old 02-15-2012, 10:06 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
I have heard the lube locker gaskets are a superior alternative to RTV.
Old 02-15-2012, 11:40 PM
wallz's Avatar
wallz
wallz is offline
Good time to change the cover out if rusty. That 08 finned alum one sure looks purdy!
Old 02-16-2012, 06:55 AM
fishintheobx
Awesome. Thanks for the info...
Old 02-16-2012, 09:38 AM
labman1014's Avatar
labman1014
labman1014 is offline
Where can u get one of these? Do they make them for the front also?
Old 02-16-2012, 12:09 PM
EXv10's Avatar
EXv10
EXv10 is offline
Lot's of good sealers out there.
Old 02-16-2012, 04:24 PM
hasteranger
I'd start at lubelocker.com
The dana 50 has the same diff cover as the d60.
Old 02-16-2012, 05:10 PM
Skinsfan6's Avatar
Skinsfan6
I think the lubelocker gaskets are reusable too. Pretty awesome if you ask me.
Old 02-16-2012, 05:49 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I use only permatex rtv's and like the gray for most applications. The important thing with RTV's is not to use to much. There should only be a minimal squish out when fully torqued down. Most of the time I just smear it on with my finger instead of laying a bead down. A bead is normally to excessive and lots of times doesn't give 100% coverage on the mating surfaces. Wiping on a thin layer you get the 100% coverage while using much less RTV.
Excessive squished out RTV while an eye sore on the outside is also bad for the components it is sealing up when it breaks off on the inside and starts plugging up tubes, bearings, gears and whatnot. I have seen oil pick up screens completely blocked by RTV from the oil pan gasket.
See nice uniform and minimal squish out of the RTV at full torque.
bigcountry1009
1999 to 2016 Super Duty
10-27-2014 08:37 AM
'78F250351m
18
08-16-2013 07:46 AM
dohc_chump
02-18-2011 06:05 PM
jenkinsj
11-26-2005 07:33 AM
Sixoh
07-27-2003 05:22 PM
Quick Reply: '05 Rear oil change - any gasket?
