Dash lights don't work - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-15-2012, 07:57 PM
mzbh mzbh is offline
mzbh is starting off with a positive reputation.
2003 F250 7.3L V8 Diesel 100,000 miles FX4 Crewcab.
Installed a new Sony CDX-GT40UW to replace the factory 6 disc radio.
When I connected the new ground to the new wiring harness, into the old radio plug, my dash illumination lights, factory fog lights and running out side lights went out. I replaced the fuse 15A under the steering coumn, moved the ground to another location (local screw). The running out side lights are back on but the dash lights are still out. Also the factory fog lights are not working and the "you left your lights on" warning chime is not working.
All the dash lights are out. Dash light as in the lights behind the tachometer and speedometer. The sensor aka "idiot" lights all work. Is there a way to get to the bulbs or did I do more damage? I really need to see the speedometer while I am driving at night!
The radio worked the entire time, even with the blown fuse.
The switch for the dash lights will control the interior cab lights and turn the main lights on and off. But it is not illumined either.
Upate: Took dash apart and found no obvious problems. For those like me who didn't know. There are only two scress in the radio bracket that hold the piece of dash board front cover around the display . The lights for the display are easy to get to once you take the full unit out. The bulbs also looked ok, not burnt out. The light assemblies are $8.50 on line at Ford.com and $10.50 at my local official factory dealer.
Does any one have any idea what could be wrong?
Old 08-24-2014, 09:49 PM
lmorris10 lmorris10 is offline
lmorris10 is starting off with a positive reputation.
any luck?
just bought 2000 f250 and now see interior/dash light, park lights, high beam don't work......
2001 expy low beams and fog lamps inop 68f10059 1997-2006 Expedition & Navigator 6 12-01-2016 01:22 AM
98 e150 instrument lights-Strange Issue rustypierce 1968-2013 Full Size Vans 6 10-27-2016 03:24 PM
Dash lights partially working FordBoy2012 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-16-2016 11:52 PM
Fuse 16 (parking light) burns out in 2min EppNation 1999 - 2003 7.3L Power Stroke Diesel 14 03-19-2015 07:43 AM
2004 SD speedometer and HVAC lights dead fre1102 1999 to 2016 Super Duty 1 11-20-2014 07:02 AM
Tags
03, 2000, ac, cluster, dash, dont, f250, ford, ground, gt40uw, instrument, lights, panel, sony, superduty, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
