How often do you change your fuel filter?
<li>Oil changes on schedule are more important than many other motors due to the hydraulic functions it serves for injectors, etc.</li>
<li>Use a good quality CI-4+ rated oil - don't waste money on CJ-4 since you don't have all 2007 emissions crap</li>
<li>Use the 15w-40 unless you live in extreme climates. The HP oil pump will shear it down to a 30 wt, and some guys use 10w-30 instead because it doesn't shear as easily.</li>
<li>Only use Motorcraft Oil Filters, no other brand due to fit issues - it's a FL-2016</li>
<li>Coolant flush and fresh is a big deal also - plenty of horror stories on plugged up EGR coolers that have led to engine melt-down.</li>
<li>Take a good look at the REV-X product. A lot of 6.0 owners have some real success stories from it.</li>
<li>Before you change out what's in there, consider getting a Used Oil Analysis from Blackstone or another firm to understand if there are bigger problems inside (ie: coolant, fuel, etc. in the oil)</li>
When it comes to lubricants advice I head on over to Bob is the Oil Guy Forums. There are some guys that are pretty fanatical about lubricants there and have test data and results to back it up. You'll find plenty of discussions on oil in the 6.0.
Looked at the filter cited above and it's a cartridge and o-ring in the box... I thought someone swapped something else in there! Is this right?
Also, trying to decide if I want to buy the Mobil1 for turbo diesel trucks vs. the Mobil Delvac conventional oil.
I read the forum referenced above, but still torn. Anyone with experiences on either?
Thanks in advance!
Thanks in advance!
You'll get just about ever answer under the sun to that question. Everybody has a preference that fits them. All depends on driving habit, climate, and what you plan on doing with the truck. Some are into synthetics, some are not. Rotella is good stuff, but many would argue it's not the best. I know a guy that ran Rotella diesel oil and the wrong viscosity in a jeep since brand new (because he got the oil for free at truck stops). That jeep has over 280k miles today. So as they say, "your mileage may vary". But when it comes to the 6.0, these are the rules:
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
