Right Floor Board Constantly Wet
Like the description says my right floor board is consistently wet under the carpet to the point of being able to feel it from the top side.
Nothing was spilled on it or anything in a while but it has rained lately. Seems to be coming out of that grommet in the floor, but I duct-taped it really well because I cut a small hole for amp wires to come through. It starts there and goes back and to the right.
Ill post pics as soon as I get the chance later tonight. But if anyone has that same problem please post up and if you fixed it what did you do? Door seal mod?
Thanks!
Thanks!
Well here are some pics of where I think the water is coming in from.
And I'm sure its water no antifreeze smell.
You can see my terrible wiring job, but it gets the job done. don't mind the rust in the pics its a WV truck, but its new home is the less salty NC. Do you think a good shot of water proof foam insulation will do the trick inside those holes?
Like I said rusty, but I feel like this is where the water is coming from? Would the foam work or is there a better solution besides moving the wires, I have tried to re route them but they wouldn't reach the amps.
Thanks!
Thanks!
Try to put a drip loop in the wires before they enter the cab, so that any water running down the wires has a chance to drip off, rather than running directly to the floor. You do need to seal that hole somehow - perhaps with a grommet from the hardware store.
The duct tape isn't really preventing the water from entering, but if you use foam, realize that most aerosol foams can hold water and make rusting get much worse. So, use them sparingly, or try another approach.
I just wanted to get clarification on what the A/C heater box is. Are you talking about the heater core that's inside the cab just behind the glove box in the dash against the firewall? And where is this drain you are speaking of?
I too have had water leakage onto my passenger floor pan and it's created a great deal of rust. There's also the musty/mud odor in the cab too when A/C is running and I can actually see the water dripping under the glove box onto the floor. This drip always coincides with the A/C turning hot. I've cleaned out the evaporator housing in the engine bay with a garden hose and still have the problem. Oh, and there are no holes in my floor pan.
Thanks,
Drake
Drake, you should have a tube or hole coming out of the HVAC (thats the black box that the heater core/AC condenser are mounted in). this tube will be on the bottom of the box on the passenger side, on the engine side of the firewall. Kind of a confusing explanation.
as the moisture collects on the condenser it will drain into the bottom of the HVAC assembly and then its supposed to drain out that tube. If it gets plugged the water has no where to go but inside. Mold will begin to develop and thats where the smell come from. once you find the drain, GENTLY probe around with a piece of wire or some such to reopen that tube. I have also used compressed air to clear out the drain. Once done, there are some aftermarket sprays you can spray into the vents to kill the mold and freshen up the air. I'm sure someone (PasonPSD or ?) has a pic that makes this more obvious. you may have to repeat this a couple of times over a span of a few weeks to get all the chunks cleaned out.
hope this helps
Barney
hope this helps
Barney
hope this helps
Barney
hope this helps
Barney
Jake_TheGreat
09-13-2018 11:01 AM
ctubutis
Garage & Workshop
09-17-2010 02:15 AM
