4R100 Transmission - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4R100 Transmission
Old 02-15-2012, 01:26 PM
dire straits dire straits is offline
dire straits is starting off with a positive reputation.
Smile 4R100 Transmission
Hey Guys
Just purchased an 04 F250 SD with 63360 miles on it last week and I was looking at the transmission section in the mnaufacture's s Scheduled Maintenance Guide to see if I should have the transmission service and I noticed the only maintenance they call for is a fluid change. Are there any filters, screens etc. that need to be changed?
Dave
Old 02-15-2012, 02:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
That depends on which transmission you have. If you have a gas engine the trans is a 4R100 and does not have a scheduled filter change. If it is a diesel there is a filter near the radiator that should be changed at least every 30k miles.
Old 02-15-2012, 06:04 PM
fordguy622's Avatar
fordguy622 fordguy622 is offline
fordguy622 is starting off with a positive reputation.
Tranny Fluid
Hi All,
I'm going to futher the question at hand and ask what a good synthetic tranny fluid is to use. Also even if the scheduled maint. does not call for a filter change, should there be one at some point? (this is for the gas motor)
Thank you,
Ron
Old 02-15-2012, 06:15 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
If you're flushing it regularly and driving it normal, I can't see any reason to "need" a filter change. Shouldn't be enough stuff getting into trans fluid to "fill up" the filter. That being said, it is not that hard to drop the pan and change the filter every now and then. Good excuse to take a look inside the pan and inspect/wipe off the magnet. Also rather easy to add an in-line "fine particle" filter as used on the diesels, just for peace of mind.
200K trouble free miles on my 4R100 and counting.
Old 02-15-2012, 08:41 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
92f150I6 is gaining momentum as a positive member of FTE.
Not to hijack, but this thread has me interested. Anyone know how much fluid is needed just for a drain and refill on a 4R100?
Old 02-15-2012, 09:03 PM
fordguy622's Avatar
tranny
The owners guide says 16.7liters or 17.7 quarts of mercon atf
Old 02-15-2012, 09:05 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Quote:
wth type f thats a pricey change!
Old 02-15-2012, 10:51 PM
iamrfixit iamrfixit is offline
iamrfixit is starting off with a positive reputation.
Quote:
Don't do that!!
Type F is the wrong fluid for this transmission and would probably cost you a whole lot more than just the price of the fluid!
Mercon V is what you need, that is the replacement for Mercon. On my 2000 I have a drain plug on the torque converter as well as the pan. I drain both, drop the pan and change the filter, takes exactly 15 qt to refill. I gave $64/case for Motocraft Mercon V at Oreilly's.
Don't damage the gasket it can be reused, my pan has been off 4 times and I reused the gasket every time.
Old 02-16-2012, 12:06 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I tried to drain TC but PO torqued the shield bolts out of proportion. I got 18" brake bar and good socket, yet 2 of the bolts are stripping the heads. Any tips how to deal with them?
Old 02-16-2012, 02:40 AM
Skip1970's Avatar
Quote:
Originally Posted by iamrfixit View Post
Don't do that!!
thats right mercron v is the expensive stuff not type f
Old 02-16-2012, 06:02 AM
Thanks Guys....great info.....FTE rules!
Old 02-16-2012, 09:01 PM
I prefer Mobil 1 synthetic ATF. There is no scheduled mileage to change the filter. If it needs to be changed the trans is already trashed.
Quote:
If you are just draining the pan it's around 8 quarts.
That includes the torque converter and all the lines. You won't get that much fluid out of the trans by draining.
Old 02-17-2012, 05:40 AM
Thanks, Mark
Old 07-17-2012, 11:30 PM
Sportsnutim1 Sportsnutim1 is offline
Sportsnutim1 is starting off with a positive reputation.
Who designed the 4R100 Transmission?
I bought my 01 Ford Super Duty and have gone through 3 transmissions. I completed all the required maintenance and still no luck. The Ford engineers must of been on dope when they designed these especially for the 7.3. No more Fords for me.
Old 07-18-2012, 10:49 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
only the 5 speed torqshift has a external spin filter, not the 4r100's.
F-350 maintenance Gorgoth Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 05-27-2016 01:54 PM
Hard shifting after warmed up Willard13 1987 - 1996 F150 & Larger F-Series Trucks 13 12-14-2015 12:32 PM
75K Maintenance - Did I miss anything? Tawn 6.4L Power Stroke Diesel 4 01-19-2014 11:38 AM
2005 Escape transmission filter coreyp Escape & Escape Hybrid 3 01-30-2011 06:05 PM
Sealed transmission? Gary42141 Clutch, Transmission, Differential, Axle & Transfer Case 5 12-18-2004 05:12 PM
Tags
2002, 4r100, 54, drain, duty, f250, fl, ford, long, performance, refill, series, south, super, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
