What's the largest comfortable tire size fit for my Superduty - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-15-2012, 01:35 PM
Ironman20102002 Ironman20102002 is offline
Ironman20102002 is starting off with a positive reputation.
I have an 03' ext cab f350 superduty that has a v10 and leaf spring suspension stock tire size is 265/75/r16 i just want a comfortable wheel well fill w/o leveling kit or lift i know there are a ton of threads on this but i just havent found anything matching my situation or at least detailed that i have found your help and knowledge is greatly appreciated
Old 02-15-2012, 01:43 PM
theres the picture
Old 02-15-2012, 04:09 PM
AJB201 AJB201 is offline
AJB201 is starting off with a positive reputation.
you can go to a 285/75/16 on a factory rim without any rubbing. That is what I have on my 04 F250.
Old 02-15-2012, 04:58 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
Based on how tight the 285s are on my truck, I would not go bigger on a stock truck. You won't be able to run front tire chains with a 285, FWIW
Old 02-15-2012, 05:08 PM
Rongold's Avatar
Rongold Rongold is offline
Rongold is gaining momentum as a positive member of FTE.
Tire Size
I have 285/75R-16 Cooper AT3's on my truck with stock plow suspension (X code front springs). I have no rubbing or problems. However, they do not fill the wheel wells. According to Cooper, they are 1" wider and 1" taller than the 265's. The next size up is 315/75R-16, and they are 3" taller and 2" wider than the 265's. They will probably hit the leaf springs on turns. Unfortunately, the only way to find out is to try them on. Also, anything larger than 285's will require wheels wider than the stock 7".
RON
Old 02-15-2012, 08:05 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
I have 295-75-16. They rub at lock. use to have 285 and they did not rub.
Old 02-15-2012, 08:51 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
285's since stock rims are pretty narrow... 305's and 315's will balloon pretty good if you put them on stock rims. I had 315's on 8" wide rims (the minimum recommended width) and that was still a bit narrow. They also squirmed pretty good. Put my new 315's on 10" wide rims and now they wear even and hardly squirm at all. Pretty happy!
Old 02-15-2012, 09:34 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
92f150I6 is gaining momentum as a positive member of FTE.
I run 305 nittos in the summer on 10" wide wheels and only rub the air dam a little. My old 305's didn't rub at all. I have 285's on stock rims for winter, no rubbing at all, but don't fill up the wheel wells like the 305's.
Old 02-15-2012, 09:39 PM
dkf's Avatar
dkf dkf is online now
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
For me 285/75R16s or 295/75R16s are what I would run, the 295 being the largest I would go. I currently have 285s and will keep buying them as I think they are a very good size for a stock height truck and stock wheels. My 285s are pretty aggressive but they do not rub at all.
Old 02-15-2012, 11:28 PM
Sweet cause I just want a bit bigger I'm buying Goodyear duratrac AT cause I'm not off road as much as I used to be and I have firestone dest MT but I like aggressive so an aggressive all terrain is nice look and still off road ready for me if I get a 2 am " I'm stuck" call
Old 01-28-2013, 11:33 PM
ronhestergto ronhestergto is offline
ronhestergto is starting off with a positive reputation.
My 1999 250 s duty, came with 35/12.5r18, that rub bad, found set of 265/70r17 custom wheels, with 1/2 tread dept. Would this be a good way to go? Will be pulling trailer with it. Also concerned with looks, as the 18, look so good, but too much offset, stick out, and rub l alot, just looking for thoughts ,I dont like the 16in wheels, they look to small, thanks
Old 01-30-2013, 07:56 AM
bthr22's Avatar
bthr22 bthr22 is offline
bthr22 has a good reputation on FTE.bthr22 has a good reputation on FTE.
Quote:
I'm pretty new to everything here, so what exactly do these numbers mean? I'm guessing the last number (R16) is the radius from the center of the wheel hub to the edge of the tire? Thanks!
Emergency equipment storage with pics and list - Everything fits!! 07EXPYEL 2007 - 2014 Expedition & Navigator 0 06-07-2016 12:51 PM
Will “F 151” on my 78 Ford F 150 Title get me some grace at Emissions in Maricopa County, Arizona? Ira Brown 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-19-2014 12:00 PM
4x4 not engaging - 2000 F350 7.3 (Manual Hub) TowsonX 1999 to 2016 Super Duty 5 01-11-2014 11:25 PM
Changing Tire and wheel size Rickx 6.7L Power Stroke Diesel 7 10-12-2011 07:43 PM
oxygen/acetylene torch question..... rockher_man 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-02-2010 09:28 PM
Tags
2002, 2011, 285, amateur, company, duty, f350, ford, general, largest, powered, radio, size, stock, super, tire, tires, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
