Engine Mounting Kit for 351M - Ford Truck Enthusiasts Forums
Old 02-15-2012, 12:13 AM
fomocodan fomocodan is offline
fomocodan is starting off with a positive reputation.
I am wanting to installing a 351M into a1960 F-100. Is there a engine mounting kit made for this. If so, where can I purches one.
fomocodan
Old 02-15-2012, 08:41 PM
cparks cparks is offline
cparks is starting off with a positive reputation.
The 351M or 400 engine is not that common in swap type applications. They are also unique to themselves. I have not seen anything specifically for those. You see a bit of the small block 289 302 351W 351C mounts, then the FE 390 etc type, and 429 460 engines.
Old 02-15-2012, 08:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Jegs has the weld in type. I haven't seen any bolt in ones if that is what you need.
Trans Dapt 4513 Trans Dapt Universal Street Rod Style Bushing-Type Motor Mounts
engine mount fitment 351M/broncograveyard winginit 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-05-2016 08:13 PM
351 ranger swap twalters Ranger & B-Series 2 12-23-2015 11:47 AM
1965 F100 400ci engine swap TheThickster 1961 - 1966 F-100 & Larger F-Series Trucks 10 09-09-2009 10:03 PM
351M to 302 engine mounts hartmark 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-08-2002 09:34 PM
351m-351w engine swap trukster59 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-03-2001 05:48 PM
Tags
1960, 1996, 351, 351m, engine, f100, ford, kit, motor, mounting, mounts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
