Broke my DFCM Housing ** HELP **
I just got back from the dealer, I was correct when I listed the lower "Bowl caps part number is #9G270 and if your not careful the Water - Fuel sensor can be broken also. That part number is #9T321. They where priced at $64.25 and $29.65 respectively.
I made them let me watch as they repaired the cap and I believe I twisted it the wrong way. If you read the manual it says Counter Clockwise which when looking from underneath is to the Left however that is not correct. It must of meant from looking above. The easiest way to state the above is look at the tab on the cap. It needs to go down and around the fuel pumps tab. This should be twisted to the back rear tires when looking at it from below. DO NOT TWIST TOWARD THE RUNNING BOARDS. Twist toward the rear end. Lesson learned.
Also on side note be careful, they wanted to replace the whole fuel pump when I knew without a doubt all that needed to be replaced was the cap "bowl". In there defence they said that, as a warning if they had trouble getting the overtighted cap off.
