Hot Wires!
But not before you pull that thing out of the garage and get us some pictures. If I had the choice of driving my new truck around this weekend and getting to know it vs. doing a 12 volt conversion, I'd at least take my woman down to the local drive in and get a milkshake. Who knows, she may think that slow crank of that big powerful 6 volt battery is the sexiest thing she's ever heard. I'm just having fun with you man. I am glad those thicker cables fixed it.
Yep. Good old Ohm's law and all of its concepts. These same principles are why houses burn to the ground every day when an inappropriately small wire can't handle the amperage. Imagine if that cable was buried inside a wall or attic......... When a breaker (or fuse) kicks in a house, there is a reason. That reason needs to be found. Same principles apply for an automobile.
Hmmm....I'm not sure what to say!! Doc...if this is your dream woman...we need to get you out here to California on a little vacation!!!
Doc, your comment on the 6V starter and using 12V to start reminds me of an old WD Allis tractor we had years ago with a loader on it. It would sit outside for weeks at a time without starting and then we would need to use it. The battery was generally weak because of no use. We jump started it for years with jumper cables hooked to 12V from the pickup and never had a problem with the starter.
Pulled the girl out and took some pics. Here is the thread with the pics. Took a nice drive and went through all of the gears. The drivetrain is fine but I will need to get a rebuilt steering gearbox. Anyone know where I can get one online? Here is the link to pics. Enjoy! https://www.ford-trucks.com/forums/1...y-1951-f1.html
PA79F150
02-24-2005 12:23 PM
rander101
03-16-2002 07:52 PM
doop
10-25-1999 07:46 PM
