Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 02-14-2012, 04:59 PM
PaulsEdge PaulsEdge is offline
Garage is empty, add now
PaulsEdge is starting off with a positive reputation.
Considering Propane Conversion - have question about heads burning out
Hi everyone, this is my first post to this forum. I am considering a conversion to liquid Propane dual gasoline fuel system for my 2009 Ford Edge (V6, 3.5L).
I've talked to the conversion company, and I've talked to my Ford dealer about it. The dealer is telling me that they deal with many Propane vehicles, and that I can expect to replace my cylinder heads every 100,000km or so, at a cost of approx. $3000-$5000 And he advised me to replace them for "hardened" heads which will last 200,000km but will still eventually need replacing.
I then called the conversion company up, and they told me that the dealer doesn't know too much about the conversion process, and that with proper tuning of the air/fuel mixture (not too lean or rich) that the temperature should be okay for the engine to handle, and they went on to say that they have converted taxis that have run for a million kilometers on Propane without any troubles.
Whom should I believe?! Because of this issue, I am sitting on the fence about whether or not to convert. Does anyone have any experience in this regard, or can anyone offer an informed opinion on this? Thank you kindly for any help.
Paul.
  #2 (permalink)
Old 02-14-2012, 06:36 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
Most modern engines properly set up will handle the conversion without any issues. That being said you can burn/drop a valve on gasoline. The key is maintaining your system filters clean etc. I have owned a few Lp units and worked in the industry for a "few" years and never had any issues.
Good Luck
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #3 (permalink)
Old 02-15-2012, 09:15 PM
Thanks gasman! That's what I was hoping to hear. I'm not sure why the Ford dealership would try to scare me away from a propane conversion? By the way, by keeping my filters clean, you mean the propane filter which has to be done every 80,000km or some other filter?
  #4 (permalink)
Old 02-16-2012, 07:07 AM
gasman6674's Avatar
1996 Ford F-350
Propane filter, air filter, the vaporizer if used will need to be serviced every 50,000 or so.
Basically just maintain iy and you shouldnt have any problems.
Good Luck
__________________
Jim England
Tags
1994, 2009, 350, 351, 351w, 49, block, conversion, convert, ford, heads, propane, small, truck, windstar, winsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
