1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F-350 Sway Problem
Old 02-14-2012, 04:12 PM
Texas 6.0's Avatar
Texas 6.0
Texas 6.0 is offline
F-350 Sway Problem
Have a 2005 F-350 4x4 SRW 4 door LWB, noticed a week ago the truck "swaying" while changing lanes (real bad at 60mph or higher). Have purchased new tires (stock GY 275-60-20), replaced shocks (MX6 - 4 wheel parts), and in Oct replaced the drag link and tie rod end (from the pitman bracket to the passenger side top) with FORD parts.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
While driving at 55 or 60 and change lanes the truck will sway back and forth two or three time before it stabilizes out?<o></o>
Things that I have checked:<o></o>
REAR<o></o>
leaf springs not cracked or loose<o></o>
lifting blocks tight no signs of movement (been on the truck since 2007)<o></o>
sway bar bushings look good <o></o>
new shocks<o></o>
FRONT<o></o>
2" lifting spacer not damaged<o></o>
all other tie rods look good <o></o>
new shocks<o></o>
<o></o>
Any help would be great!<o></o>
Old 02-14-2012, 06:53 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
How about air pressure in the tires. Are both fronts the same and both rears the same pressure? What are the pressures set at? It seems to me that tire stores never set pressures correctly.
Old 02-14-2012, 07:04 PM
F250CCowner's Avatar
F250CCowner
F250CCowner is offline
Have you checked ball joints? Bad ball joints could be part of the problem.
Big-Sarge
6.7L Power Stroke Diesel
168
10-28-2022 02:54 PM
Akhnot
01-04-2021 07:58 PM
Texas 6.0
02-19-2012 09:14 PM
sddesigns
New Jersey Chapter
90
11-19-2009 10:28 AM
Flip4ford
Kansas Chapter
06-18-2007 06:17 PM
Quick Reply: F-350 Sway Problem
