What is this?
No, they are (as already mentioned) negative ("ground") straps. Trusting hinge pins (that SHOULD be lubricated with some regularity) to be a decent conductor between hood-and-body or door-and-body is, how do I say this politely... a less-than-intelligent assumption. There are a few between cylinder head and frame or block as well since there is no way to be certain that bolts covered in anti-seize or lock-tite will conduct to the heads and having strong negative continuity at the heads is CRITICAL for spark strength. By the same token, your under-hood courtesy lamp will not function if the hood hasn't got a strong negative connection.
I did a reground upgrade on my Bronco whenever I did the 3G swap. I used 4ga wire and soldered some nice big copper lugs onto them. I took it from the battery to the block. Then I went from the block to the frame and frame to body. I like the idea of the head to block ground wire. I believe I will add that as well as a block to starter ground.
I think I am going to have my exhaust shop money together by the end of next week. Thats all I really lack on putting the 87 Bronco back on the road. The new motor should be bumping a little over 400 hp at the crank. I designed the motor to have at least 350 hp to the wheels. It may have more than that though.
spacemarine83
13
12-28-2023 09:43 PM
flowney
650
11-12-2023 03:55 PM
Goobzilla
10-08-2004 11:10 AM
