emissions diagram or picture? - Ford Truck Enthusiasts Forums
Old 02-14-2012, 01:12 PM
emallen's Avatar
emallen emallen is offline
emallen is starting off with a positive reputation.
Hi all, got all the electrical working on the old truck, and now am going to tackle the emissions.... luckily in PA (for now) the emissions "stuff" doesn't have to work, it just has to BE there. So long as it looks good to the inspection mechanic, it passes.
Years ago we took most of the emissions stuff off and threw it in the junk pile (I know, pretty dumb ). Luckily, I was able to recently re-gather most of the bits and pieces from other sources. So earlier today I took a deep breath, opened the manual, and lo and behold the emissions-related pages in the book are MISSING (along with half the electrical, and some of the cooling).
Could somebody either take a picture of their *perfect* engine emissions setup, or maybe even a picture from a manual??
Thanks!!
edited to add, if it matters, and probably does, I have a 300 6-cyl. carb, used to have air conditioning.
Old 02-14-2012, 01:59 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
I was all set to help you up until you said 300-6. I've only owned 1 and it's emissions equipment was LONG gone by the time I got it.
Yeah and transmission are probably needed too.
Just find a mechanic that isn't familiar with the older trucks and let him think that everything is there...
Or spend the money and get the waiver and keep mileage under 5k. These trucks sometimes suffer from intermittent speedometers where the cable sometimes falls out of the back of them...
Old 02-14-2012, 02:12 PM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Why are you recommending odometer fraud ? That ain't cool....
Old 02-14-2012, 02:35 PM
These trucks have long since been exempt from mileage disclosure and I don't remember how many times I've swapped tach clusters with trip odometers in and out of trucks where mileages have varied greatly up and down...
To each his own I guess and if the mods feel the need to edit anything I fully understand.
Old 02-14-2012, 02:40 PM
KingBigJoe's Avatar
I know that the old trucks are for the most part mileage exempt & the miles on these old trucks are "write-offs". But, it is a federal crime to tamper with the odometers just for future reference.
Old 02-14-2012, 02:45 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Thanks!!
Your most accurate diagram will be on the radiator support. Take a photo of it if you can. Even if you told us the year(which you need to do) we could only get you close.
Old 02-14-2012, 02:51 PM
Quote:
It's also a federal crime to remove emissions equipment...
It's good to point out though. The OP can make his own decision on what to do.
Old 02-14-2012, 02:55 PM
KingBigJoe's Avatar
F100... I wasn't trying to be mean when you recommended the odometer fraud. As I look back & read it... I sounded harsh. I'm sorry.
KBJ
Old 02-14-2012, 03:01 PM
Thomas Boersma Thomas Boersma is offline
Thomas Boersma is starting off with a positive reputation.
Once a vehicle has had an issue with the odometer, such as being non functional, replaced, rolled over, or otherwise inoperative, the vehicle (in most states) becomes odometer exempt, which is common on older vehicles. While there is a federal law against tampering towards misrepresentation of true milage for selling purposes, it is not illegal to have an inoperative odometer (in most cases) or to work on it yourself.
Old 02-14-2012, 03:34 PM
emallen's Avatar
Thanks for the conversation! I did look into applying for the exemption, but it was way more time-consuming and complicated than I was into. It involved getting signed letters from parts dealers, junkyards etc.., as well as numerous and ridiculous forms to the great State of PA.
I figured it was easier to wing it, put enough pieces back on, and run enough hoses I could get some one to pass it without endangering their license. Franklin, the diagram was by the radiator like you said, never paid much attention to that side. That will help.
Sorry! My truck is a 1982... I'll edit my avatar or whatever so that I have all the specs up front.
Old 02-14-2012, 03:47 PM
emallen's Avatar
I have to have 25 posts to add a signature...
1982 Ford F150 Custom XL shortbed 4WD 300 6yl 4-speed standard!
Old 02-14-2012, 04:44 PM
KBJ
I wasn't trying to be mean back, which is why I said thanks for pointing it out.
Little in life is black or white, we have so many laws on the books that they've lost count. So sooner or later we're going to get to that line and have to make a decision. I believe in people making their own decisions. I made light of it but it's good to point out there could be problems.
It's all good. Sorry if I sounded harsh to you.
Also, in PA, any vehicle more than 10 years old can be exempted from mileage disclose. It isn't mandatory and I've disclosed mileage on older cars but you don't have to. Once exempted on a title it's exempt. There is no more reporting of mileage.
Old 02-14-2012, 04:51 PM
If you get a PA licensed emissions mechanic to do the work or at least sign off on receipts you bring him you can get a one year waver. The fee used to be $450 but I think it's been lowered to $150. You do not have to bring it into compliance to get the waiver, just spend enough money this year and they'll expect more repairs next year or a mileage exemption. I have a couple vehicles so my truck usually gets around 3,500 miles/yr. One once did I get close.
Call a shop or two, of better yet, go over and talk to them in person and tell them what you have and ask about the waiver limits. If you drive less than 5k a year it might not be worth fixing.
It's been years since I've done it, but I've gotten waivers before. In fact the first year I had my 86 F150 it got a waiver, the second year it passed by the skin of it's teeth and it's been mileage exempted since.
Old 02-15-2012, 07:34 AM
emallen's Avatar
Thanks guys for the responses. I still think I'll try first to put the emissions components back on... Partly because I'm allergic to fees and waiver forms and all that .
I ordered a used Haynes manual from Amazon, cost me only $7.31 total. I needed another manual anyway since the spine came off my my original, and is in about 100 chunks with lots of missing pages. I don't know how good the Haynes manuals are, but it was cheap and worth a shot.
Old 02-15-2012, 08:21 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
My preference in manuals are the same ones that they use at the dealerships. They are made by a company called Helm Inc., here is their link;
Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated
They are not cheap, but they are the best. If you plan on keeping your truck for a long time, these are a very worthwhile investment.
1985 Emission control devices Handdsaw 1968-2013 Full Size Vans 11 05-11-2015 01:02 AM
'86 Removing Emissions & Timing Chain Install quakerj Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 09-17-2013 05:06 PM
PA emissions, 5 Star and me D8chumley 2009 - 2014 F150 20 04-28-2013 06:56 AM
emissions junk on a 78 F250army45d 1973 - 1979 F-100 & Larger F-Series Trucks 41 09-20-2011 09:51 PM
1989 F700 429 factory emissions equipment Gale Hawkins 1987 - 1996 F150 & Larger F-Series Trucks 3 01-02-2010 03:08 PM
Tags
1980, 1982, 93, emissions, emmisions, f150, ford, picture, schematic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
