Serpentine Belt change out on 2005 F-150 V8 5.4 - Ford Truck Enthusiasts Forums
Old 02-14-2012, 01:53 PM
bighunt34 bighunt34 is offline
bighunt34 is starting off with a positive reputation.
Degree of difficulty? I've never done before. Not on any vehicle. Tools? Time?
Got one quote from a shop for $137 (I think, maybe $173 though
Any input would be appreciated?
I have a Chiltons to guide me but would appreciate any other tips I can get!
Thanks in advance!
Old 02-14-2012, 02:24 PM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
I did mine last July. It is not bad at all. I paid 32 bucks for the belt. Do it yourself, you'll save a lot of money. Here is a link to a thread I wrote about it on here. It'll tell you what you need to know. I also changed an idler pulley while I was at it.
http://www.ford-trucks.com/forums/10...tine-belt.html
Old 02-14-2012, 02:30 PM
bigunit54's Avatar
I guess I shoulda read your post better. If you haven't ever done any vehicles belt should know it is not difficult if you have basic mechanical knowledge. You will have to remove the breather tube that feeds the air filter box, then you can get to the belt. You will need a long 1/2 in drive ratchet to move the tensioner pulley, I think you move it from your left to right as you are facing the vehicle, if I remember right. Like I said I used my torque wrench to move it as it had the longest handle of any ratchet I got. If you have never done one the whole thing should take you about 20 minutes.
What are these called and where can I acquire them? Nofear202 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-19-2016 02:20 PM
Power Point Fuse Alex Ulmer 6.0L Power Stroke Diesel 3 10-25-2013 10:12 PM
interior knobs JUSTICE1736 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-05-2012 02:08 PM
IAT southern hunter56 1987 - 1996 F150 & Larger F-Series Trucks 7 03-23-2011 05:20 PM
Mabbco Rebuild Kits lcguy1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-20-2011 08:10 PM
Tags
08, 2004, 2005, 2006, 54, accessory, belt, belts, change, f150, fan, ford, remove, replacement, serp, serpentine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
