Tank question
Tank question
So I am slowly assembling a two tank SVO conversion for my 99 Powerstroke. But I have a question about the second tank. I can get my hands on a tank that goes where the spare tire mounts for $80, but the tank is made of steel. So I have a 2 part question.
1. Could I seal the steel tank with something like this, and not have to worry about polymerization?
2. Should I make the steel tank my diesel tank, and convert my stock tank to the SVO tank?
why do you want to coat the steel tank ?
what are you going to use to heat the oil ?
veg oil will not react to the steel as far as i know !
i have a side tank off of a older F700 that i am in the process of converting for WVO !
by converting i am building a heater system for that the coolant will run through , probably wont work to well !
No, there is not any coating I am aware of that will tolerate hot WVO. (I work with industrial coatings every day )
I suggest selling the Cab Chassis tank and getting an X tank. I see X tanks go for <$100 all the time. Check car-part.com
No, it won't work well for long. VO will polymerize (natural degradation process) much more rapidly if exposed to CARBON STEEL. That reaction is further expedited by HEAT and even further by OXYGEN. If your 'heater system' includes copper components (much more reactive than carbon steel ) - you will effectively create a polymerization factory.
Also, by focusing your heat just around the fuel pick-up and minimizing heating the whole tank - you can reduce the rate of polymerization even further. I recommend a heated sump design. Basically a small appendage on the bottom of your tank with just a couple holes to communicate with the tank. This will focus the heat in just a few pints of oil but will heat enough of the tank to melt Crisco if needed.
Thanks again for the info Jason! I did not end up buying the tank. Luckily for me, I found a spare tank lying around here from a boat project of mine. It is aluminum and measures 18X14X30 (approx. 32 gallons) and is aluminum. I figure it will tuck up nicely between the frame rails where the spare tire is. Oh and if you get a chance will you send me some details on how you did your setup. I tried to reply to your PM, but your inbox was full.
AndrewDahlin
09-18-2010 10:43 AM
SuperCharger
04-03-2007 09:05 PM
