Clutch safety switch - Ford Truck Enthusiasts Forums
Old 02-14-2012, 09:39 AM
264WSM 264WSM is offline
264WSM is starting off with a positive reputation.
My clutch switch is giving me problems starting my truck. I have to smash the clutch pedal to the floor in order to get the engine to crank.
Where is this switch, what does it look like, is it easy to bypass???
I am not an idiot and don't start my vehicles w/o the clutch pressed or the trans in "N". I'm sure some dolt started his vehicle in gear and ran over somebody. The lawyers got involved and said it was the manufactures fault (they have deeper pockets) and sued the manufacture. As a result we now have yet another unwanted "feature" on our trucks that can only cause problems.
Now that I have gotten off of my soapbox, can somebody tell me how to bypass this thing!!
Old 02-14-2012, 09:43 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Above the gas pedal the switch attaches to the master cyl. Red wires with blue stripe are the 2 you need to jump. Check to be sure your firewall isnt cracked around the MC and that your linkage isnt worn. The bushings on the clutch/ brake pedal pivot wear out as does the plastic bushing where the master cyl pushrod hooks to the pedal assy.
Old 02-14-2012, 09:56 AM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
X2 on bashby's comments. If the pedal doesn't return fully it could indicate a bushing problem.
BTW my pedal to MC bushing broke and I used my jumper cables to activate the starter from inside the cab so I could start in gear and get the truck home. Fortunately I got lucky and only had to start in gear about 4 times before I hit the highway. Many like to bash the Mazda but it speed shifted very well.
The rod is not available as a seperate part, it comes with the MC, but I was able to get one from my local junkyard. That was about 40k miles ago.
Old 02-14-2012, 10:14 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
I had to replace the lever and the plastic bushing where the pedal meets the rod through the firewall and fixed my issue on my old 92
Old 02-14-2012, 10:30 AM
Thanx for the pointers. Now that you mention it, coming out of 3rd gear is kinda sticky, which reminds me to float 4th to 5th. I'll have to check all the linkage and firewall. I'm betting something is amiss. I'll get the swich bypassed today. I take it to work (80 miles) tomorow, but then get in a big truck until Sunday, which will require a 80 mile return trip. I have to rev the engine higher than I normally do, but I should be able to float all the shifts to and from work. I'll be able to pull it apart next week and maybe steal some parts from my parts truck.
Old 02-14-2012, 10:39 AM
Thinking about it more: In this truck (my '88), the clutch always seemed to start engaging right off the floor. When I would use the low range I would have to remind myself to push the clutch pedal to the floor in order to stop. Otherwise I would fight with the brake pedal and the truck would lunge when I was trying to stop.
Is this a symptom of worn linkage??
Old 02-14-2012, 10:44 AM
Having that plastic bushing or the pin it pivots on worn will do that as it doesn't allow you to push the clutch in as far as it should. That might also fix your shifting issues too
Old 02-14-2012, 02:00 PM
bashby's Avatar
Quote:
Yes, play in the linkage will cause your pedal to engage closer to the floor.
Old 02-14-2012, 03:36 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
I have always just bypass the switch with a push button starter switch wired straight to the starter solenoid !
Old 02-14-2012, 03:56 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I would go to the wrecking yard and look for a truck like yours with auto trans. The clutch switch wiring is still there and it has a jumper plugged into it from the factory. Grab the jumper and use it on your truck.
Old 02-14-2012, 04:19 PM
Bypassing the switch would make it start easier but if it's worn out enough he's having a hard time to Get it in and out of gear because it's not fully releasing the clutch then just fix the linkage and kill 2 birds with one stone
Old 02-14-2012, 05:11 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
I bypass the stupid switch on all my trucks. I don't like having to push the clutch every single time I want to start the truck. Maybe I'm lazy or something, but I enjoy not having the switch hooked up.
Old 02-15-2012, 08:08 PM
impish impish is offline
impish is gaining momentum as a positive member of FTE.
Quote:
The stupid switch is there as a safety factor for stupid drivers.
In the case of a broken or inoperative clutch linkage, or release mechanism, or transmission "stuck" in gear (all this for manual trans only), the stupid switch prevents "power rolling" the vehicle using the battery and starter to do so. Also prevents "power roll-starting" the vehicle.
That's why my stupid switch is out of the "loop"! impish
Old 11-15-2012, 04:42 PM
ejstith's Avatar
ejstith ejstith is offline
ejstith is starting off with a positive reputation.
I've been having this problem for years & the other day I got one of those little square connectors that you can run 2 wires through then clamp it down & the metal blades go into the wires & it snaps shut. I ran the two red wires through it & mashed it down & snapped it shut. Problem fixed !!
Old 11-16-2012, 07:37 AM
bdelmar2 bdelmar2 is offline
bdelmar2 is starting off with a positive reputation.
If you are going to bypass it, I would get the factory jumper from an automatic as mentioned.
I recently had a heck of a time tracing down a problem in my truck, it would rev to 2300 or 2400 nearly every time it started, hot or cold.
The previous owner had bypassed the igniton and the starter switch which covered up the cause of the problem. It was because the signal return part of the clutch switch had quit making contact.
It fooled me because I had the firewall flex issue (has since been full plated) and the cruise control cut out still worked on the clutch. The igniton actuator was broken in the column so I couldn't use a key, but if I held the clutch switch back and used a screwdriver in the igniton slide it would start however. So I figured since the start circuit and cruise circuit were working the switch was good.
After checking lots and lots of other things and rebuilding the column, putting the wiring back as it should be and plating the firewall. I eventually jumped the signal return circuit and the problem went away.
I went to the local upullit and got the jumper for free, plugged it in and the truck has started correctly since.
I suppose I could go buy a new switch, but I'm not a big fan of pita safety gizmos either. I removed the need to press the button to pull my key and the column lock when I rebuilt the column as well.
NO clutch safety switch rick 1999 to 2016 Super Duty 5 08-18-2016 01:07 PM
Bypassing Clutch Interlock Switch geoffunkel 1987 - 1996 F150 & Larger F-Series Trucks 9 05-13-2013 12:19 AM
Clutch and safety switch? Royson12 1994.5 - 1997 7.3L Power Stroke Diesel 8 03-31-2013 07:33 PM
1995 f150 clutch problem MrGoodnuts 1987 - 1996 F150 & Larger F-Series Trucks 4 09-16-2010 02:47 PM
clutch safety switch cajunsf Electrical Systems/Wiring 2 06-18-2004 02:22 PM
Tags
150, 2007, 91, broken, bypass, close, cluch, clutch, engaging, f150, fan, floor, ford, releasing, safety, start, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
