radius arm bushings what degree?
02-14-2012, 06:35 AM
on
its a 77 4x4 with a 6 inch lift and radius arm drop brackets. what degree bushing do i need for the radius arms. plannin to relift the front.
02-14-2012, 09:17 PM
on
If you have drop brackets you should only need the factory 2 degree bushing because you are not changing the radius arm angle.
02-15-2012, 06:26 AM
on
i figured it would be close to the stock setup with the drop brackets but thanks for the reply.
02-15-2012, 12:17 PM
If the front is raised 6" and if the radius arm brackets are dropped same 6", then no change is needed.
If the front is raised 6" and the radius arm brackets lowered 3", then you still have 3" of lift to correct for with C-bushings if you want her right.
weldworks54
04-10-2009 12:35 AM
SoArkSI
01-17-2006 05:50 PM
Blueoval_boy_64
Offroad & 4x4
07-31-2004 05:52 AM
Skottt
08-29-2001 11:49 AM
1977 ,
arm ,
bushing ,
bushings ,
degree ,
f100 ,
ford ,
inch ,
lift ,
powered ,
radius ,
regional ,
transit ,
valley ,
vbulletin
