Compass and Thermometer are Dead
What would you call the display on the ceiling of my truck?
It shows my fuel millage, outside temperature and the direction i am travelling.
It has recently gone dead and i can't figure out why.
Which fuse does it run off of?
All my fuses under the dash are good.
Thanks
Any help would be apreciated.
Thanks
Not a fuse, unfortunately. The connector to the display comes loose. The only permanent fix is to take it apart and resolder it. There's guides for it, here's one:
https://www.ford-trucks.com/forums/9...t-working.html
I have heard this connector problem in the past. Mine is a little different problem. The compass direction goes blank and sometimes gives the wrong direction and says "cal" under the little square. I have tried the calibration procedure in the manual but it goes right back to doing the same thing.
