You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm working on my '60 F100 with original brakes. The hard line from the master cylinder down to the junction fitting on the frame rotted and broke. That line, like the clutch line, has a hose section in the middle. I don't see that line with a center hose section in any of my catalogs (LMC, MACs, Sacremento).
Can I just replace it with a hard line?
Thanks for any advice.
__________________ Larry
1960 F100 Custom Cab Styleside
1966 MGB
I have no idea what I'm doing. May as well get started.
You would be surprised at how much movement there is, especially under acceleration. Try some auto parts stores. Take the old line in and if they do not have a listing for it, match it up to something close.
If you must use hard line, go with a coil of at least 4" diameter, but 2 coils would be better.
I agree with both opinions. I think i would be easy to go to NAPA and find a hose that you can connect brake line to. The connections on the hose don't matter, you just need the tubing fittings on the end of the tube to match the original. That being said, a couple coils should work fine. I would say the hose is mostly a vibration dampener to prevent leaks at the fittings more so than movement. I think the hose set up would look better.
The clutch is a different story. The engine moves quite a bit compared to the frame and needs a hose.
I replaced my original hose with coils. I wrapped the line around a spray can three or four times. I did the same thing with the clutch. If you take your time and are careful, you can bend that stuff and have it look decent. I tried to keep the coils all even and square and match up with the clutch line. I am pleased with it!
