Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 02-13-2012, 08:24 PM
1badfish's Avatar
1badfish 1badfish is offline
Garage is empty, add now
1badfish is starting off with a positive reputation.
Comparison to PWR Wagon 5.7 Hemi
Anyone know of a comparison between the F250 6.2 and the Power Wagon Hemi?? Have to say, the Pwr. Wag is an awesome truck. At least awesome looking.
http://www.tunner.org/wp-content/upl...Angle-View.jpg
  #2 (permalink)
Old 02-13-2012, 08:41 PM
Brandon150's Avatar
Brandon150 Brandon150 is offline
Brandon150 is starting off with a positive reputation.
Wonder what the mpg is... rear end is a 4.56!! That's a purpose built vehicle.
__________________
2011 XLT Supercab 4x2 ecoboost, 2.5" level, 285 Pro Comp A/T
  #3 (permalink)
Old 02-13-2012, 08:45 PM
ommegang ommegang is offline
ommegang is starting off with a positive reputation.
I like the 1500 rams but as far as 2500s go, Rams would be last on my list gassers anyways. Appearance wise, they don't look anywhere near as stout as Fords or GM for that matter. I love the height of the Fords. Dodge just doesn't seem to compare. JMO. 1500, I would consider dodge, ford, gm and toyota. I really like the snub nose look of the toyotas and the outside door handles on the scab models. I don't much care for my ford interior door handles. It get's old after a while opening two doors all the time.
__________________
2012 F150FX 5.0
  #4 (permalink)
Old 02-14-2012, 06:08 AM
1badfish's Avatar
scab vs screw
as far as the Toyotas go, I like the looks of both the scab and the screw. But, the screw's cab is just too big. The rear seat reclines and slides forward. Its huge.
the Toyotas scab is just about right and the exterior door handles and normal opening rear doors are nice. Ford's scabs seem cramped. Dodges and Chevy's scabs are better.
  #5 (permalink)
Old 02-14-2012, 06:10 AM
1badfish's Avatar
Quote:
13-16 I've read. So, comparable. Just a beast of a vehicle.
  #6 (permalink)
Old 02-14-2012, 09:36 AM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT is gaining momentum as a positive member of FTE.03 SVT VERT is gaining momentum as a positive member of FTE.
Keep in mind that Dodge's transmission gearing isn't the same as Ford's. Ford's Torqueshift is geared lower, so the final drive can be taller and still maintain a very low overall ratio.
Ford 6R140
1st 3.97:1
2nd 2.32:1
3rd 1.52:1
4th 1.15:1
5th 0.86:1
6th 0.67:1
Ram 66RFE
1st 3.231:1
2nd 1.837:1
3rd 1.410:1
4th 1.000:1
5th 0.816:1
6th 0.625:1
As an example, lets look at the first gear of each:
Ford: 3.97 first gear x 3.73 gearset = 14.8:1 final
Ram 3.231 first gear x 4.56 gearset = 14.73:1 final
So even with 4.56's for the Ram and 3.73's for the Ford, they're almost equal in first gear. They even both use the same transfer case (NV271) with the same gearing, so the Ram doesn't have any advantage in 4Lo either. Both end up being about 40:1.
So, basically, a Superduty with the optional 4.30's is geared way lower than a Power Wagon with 4.56's. A good thing to know if you're looking for the best ratio for off-roading.
  #7 (permalink)
Old 02-14-2012, 02:01 PM
coobie coobie is offline
coobie is starting off with a positive reputation.
Quote:
Got to disagree about the heights of the ford verses dodge.My 2011 ford F-250 sags more in the rear than my 2004 dodge 2500 did.coobie
__________________
2006 Ford F-150 Supercrew XLT
  #8 (permalink)
Old 02-14-2012, 06:52 PM
Loaded? Fordsare just a lot taller than copmetition. Makes me feel safe and you get used to being up tall. And, it's hard for other 's to see what's in the bed, like tools. They don't sag 1 inch with a 9'2 plow in front. But, the *** does sag when loaded. I wish mine had helper springs.
__________________
2012 F150FX 5.0
  #9 (permalink)
Old 02-15-2012, 10:16 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Comparison? Hmmm...I suppose what you are comparing. Whether it is towing / hauling or offroad climbing rocks.
The SD will dominate in the towing and hauling. However...we have NO chance when it comes to offroad. The e-locker in the SD helps...but we loose so much with articulation and front / rear lockers.
The Power Wagon is an awesome truck...for what it was built for...agreed.
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #10 (permalink)
Old 02-24-2012, 06:34 PM
swann79's Avatar
swann79 swann79 is offline
2001 Ford F-250
My Garage
swann79 has a very good reputation on FTE.swann79 has a very good reputation on FTE.swann79 has a very good reputation on FTE.
swannsa
biz is right on the money. I've been looking hard at buying a Power Wagon for some time now, but have decided to stick with my beater for now. Generally speaking, the Ford has more options, is cheaper, and will tow and haul more weight safely than the Dodge will. The Power Wagon is built for off-road capability and will shine there.
I still can't convince myself to buy a Dodge, even if the Power Wagon is cool.
__________________
'12 F-150 4x4 XLT SuperCrew, EcoBoost, Max Tow
'66 F-250 4x4 short bed, 390, 4-sp.
'01 F-250 4x4, CC, SB, Lariat, V10 *FOR SALE*
'07 Foose Stallion (Mustang GT)
Tags
2010, 2012, 250, 2500, 50, 57, 62, advantage, comparisons, coyote, dodge, fx4, hemi, performance, power, ram, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
