Borg Warner CPS!
Borg Warner CPS!
Yesterday while doing some reading I saw a guy who tested 15+ CPS models. He said the best results (other than factory black CPS) were a CPS from Borg Warner.
I looked it up. It costs $25 and can be had from o'reilly's. Today I picked one up and swapped it for my CPS.
Once I verified that mine was a grey started the swap. I wasnt going to touch it if it was black.
The BW CPS was noticeably larger than the grey OEM one. So much so that I wasnt sure it would fit! But it fit perfectly.
Got the BW in and it was an IMMEDIATE difference. The idle is much smoother now. Before it was inconsistent, about 100-200 variation in idle speed. Not much, just enough to be noticeable. That seems to be all gone now. This new CPS only went in today, so I will be on the look out for changes in the truck, but so far I am pleased! The grey is in the glove box along with a 10mm ratchet just in case.
I will report back in a few days with more results.
EDIT: I just went out and drove around for a bit and did a few WOT runs. I observed no interference from the wipers on any speed setting. Perhaps this is a revised BW product or at some point Ford corrected the interference. But I didnt notice any interference. I will also keep an eye out for that.
Borg Warner CSS1603
Amazon.com: Borg Warner CSS1603 Camshaft Sensor: Automotive
O'Reilly Auto Parts - Borg Warner CPS
I got mine at oreilly. They had it in stock.
Guess you saw the info on the diesel stop: Were 7.3 PSDs underspec'd from the factory? - Diesel Forum - TheDieselStop.com
I stocked up with two of the original CPS's from Bob when he had them in stock.
I kinda threw it in the back of my head because I didnt want it to be injectors or HPOP or something. Turns out it was just a CPS.
Good find. I took my truck in for minor repair once and they changed my CPS and I was pissed. They also said they couldn't find the old one. Never again. Plus I paid $300.oo for that one when I broke down in Las Vegas one time thinking that was the problem.
I'll have to see if this new find is worth it also, and if it lasts.
Chet
Chet
Chet
Chet
