1988 F150 Fuel Gauge Issues
Old 06-27-2014, 10:27 PM
Dflynn926's Avatar
Dflynn926
Dflynn926 is offline
1988 f250
I have an 88 f250 that both tanks are reading full. They started about the same time... I think. Would this be the sending units on both or is it the switch sensor valve?
Old 07-30-2015, 05:27 PM
Anice Guy's Avatar
Anice Guy
Anice Guy is offline
Can you help I have a 1996 f250 xl,It does the exact same thing.Please if you can send me instructions on how to check ant the volts it should have also the rear tank nly stays on for about 20 seconds.
Old 12-13-2018, 04:36 PM
Juan Aguirre's Avatar
Juan Aguirre
Juan Aguirre is offline
Fuel gauge
hello I have a 1988 f150 5.0 2 wheel drive I have an issue with my fuel gauge I currently been struggling so here’s my issue
front tank works but the needle marks passed full..
rear tank don’t work whatsoever even if I change the fuel selector switch it will still suck up fuel from the front tank
i been having the issue with my fuel gauge I grabbed an after market fuel gauge and wired it up still didn’t work I am lost I kinda need help
Old 02-20-2024, 10:36 PM
Kcooper96's Avatar
Kcooper96
Kcooper96 is offline
7th Gear
Originally Posted by rla2005
The rear sender uses a Yellow/Light Blue wires for the signal back to the dash gauge. The Black wire is ground for everything related to the tank pumps and sending units. The EVTM diagram above is for a 1991, I also had a link for a 1988 fuel system. Ford is well known to change color coding from year to year occasionally, perhaps your '87 is unique.
I am a little fuzzy on what you are trying to accomplish. Are you re-installing a rear tank or planning to run on the front only?
I can tell you that the power wire from sender to cluster on my 88 is a yellow/white wire. Ford definitely changed the color coding frequently
towerwork
15
03-11-2023 04:05 AM
grizzly7.3
11-05-2014 06:32 PM
CClark56
10-11-2010 11:55 AM
strokinout
03-05-2010 12:44 PM
White EddieB
10-16-2008 04:37 PM
Quick Reply: 1988 F150 Fuel Gauge Issues
