4.6 DOHC Question - Page 2 - Ford Truck Enthusiasts Forums
4.6 DOHC Question
Old 02-16-2012, 09:43 AM
SCD SCD is offline
SCD is starting off with a positive reputation.
Sam
Any other interferences that we should look out for? What are your plans for headers? Any issues with getting the steering shaft past the motor mounts or headers?
Thanks
Scott
Old 02-16-2012, 10:21 AM
BigJ_F100 BigJ_F100 is offline
BigJ_F100 is starting off with a positive reputation.
Old 02-18-2012, 11:21 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by Drewsc View Post
Sam, you recomend a column shifter over the floor shifter? I had thought about one as well but not sure about connecting it to the 4r70w? I haven't really looked around that much yet though. I am planning on using an under floor mounted booster as well. Great to see there are a few others using the mark viii motors. I'm sure I will be asking lots of questions. I am going to use an aftermarket harness too.
Thanks
Drew
I will be doing under floor booster, and column shift.
I am doing the Lokar cable shift (aca-1804) for my GM tranny (on the red 56), and I hope to do a similar thing for the 4r70w. Lokar doesn't make one specifically for this tranny,, but the difference is only the arm at the tranny,
and I should be able to make one to match. I'll give them a call (next week is travel again)
Sam
Old 02-18-2012, 11:26 PM
sdetweil's Avatar
Quote:
Originally Posted by SCD View Post
Sam
Thanks
Scott
I plan on using the sanderson headers as well.. and don't see any issues at the moment.. don't have them yet, so can't tell exactly.
I don't see any other issues at the moment.
here are the motor mounts
4.6 Ford motor mount kit - YouTube
Sam
Old 02-19-2012, 12:38 PM
Drewsc Drewsc is offline
Drewsc is starting off with a positive reputation.
Man you guys have some great idea's.
Scott that is also a great idea for the fuel pump. I did save the tank from the car so it may work out. Any idea what fuel tank you are using? I have the lincoln irs in mine so I think I will need a small tank.
Drew
Old 02-20-2012, 09:56 AM
SCD SCD is offline
Drew
I am thinking about 2 narrow tanks, one on each side of the drive shaft. I would connect the 2 tanks so I only have to run one in tank fuel pump. I am running the Tbird IRS. I am reluctant to place the tank in the rear because I would really like to carry a spare.
Scott
Old 02-20-2012, 10:04 AM
sdetweil's Avatar
Drew
Scott
cool idea.. think about the impact on routing of the exhaust
sam
Old 02-20-2012, 10:08 AM
SCD SCD is offline
Sam
That is my main concern. I plan on dumping the exhaust out by the running boards. You run out of space quickly!
Scott
Old 02-20-2012, 10:19 AM
sdetweil's Avatar
Sam
Scott
I ran out of space when I decided to change something!..
Sam
Old 02-20-2012, 11:34 PM
Picture Update
[IMG][/IMG]
[IMG]http://www.ford-trucks.com/forums/picture.php?albumid=25259&pictureid=93522[/IMG
Front Sheet Metal Fitment
Front Sheet Metal Fitment_2
Gas Tank
Old 02-28-2012, 06:20 PM
SCD SCD is offline
Are you guys centering the engine between the frame rails?
Thanks
Scott
Old 02-28-2012, 06:35 PM
sdetweil's Avatar
Thanks
Scott
intend to, yes
Sam
  #28
Old 02-28-2012, 07:59 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Scott,
On the question about centering the engine - We had our's an inch or two toward the passenger side to give more room for the steering & exhaust to clear on the driver's side. It get's super tight there - we needed all the room we could get - So.... Kind of centered but cheating a little over toward the passenger side.
You also need to plan out the front clearance as well. Our's got real tight between the engine & the radiator. We used a very slim electric fan & still
barely made it fit. (We put a 351W in our truck).
Ben in Austin
1950 F1
  #29
Old 02-28-2012, 08:02 PM
sdetweil's Avatar
Quote:
Originally Posted by ben73058 View Post
Hey Scott,
Ben in Austin
1950 F1
these engines were designed for electric fans, so the pulleys are very short. leaving lots of room.. I think my testfit showed about 4 inches of clearance.
Sam
  #30
Old 02-28-2012, 08:21 PM
ben73058's Avatar
Hey Scott,
Disregard my engine note above - brain cramps - not relevant to
the 4.6 DOHC you are running.
Ben in Austin
swapping 5.0 to 4.6 dohc in my 79 2wd 79 f-150 guy Engine Swaps 271 11-03-2015 12:23 PM
F100 with 4.6 DOHC MARK VIII fuel pump question. bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-06-2015 08:42 AM
rebuilding 97 f150 4.6 dohc windsor z 97ford1 Modular V8 (4.6L, 5.4L) 11 02-05-2010 07:06 AM
4.6LSOHC to 4.6L DOHC MEFFORD Engine Swaps 1 06-01-2009 12:59 AM
4.6 DOHC and 5.0/5.8 Motor Mounts..?> Mached Ranger Modular V8 (4.6L, 5.4L) 10 12-10-2003 08:54 PM
Tags
46, 56, assembly, brake, f100, intake, length, runners, underfloor, variable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
