55 239 Y-Block Restoration Thread
#1066
#1067
Sorry it's late. Just got home from our Date Night...... well monthly Pitch game with friends. Thought I would post a picture that I had on file. One of my wires goes to the left, that is the ground. Two go to the right and disappear behind the engine into the cab and connect to the switches. I can get you a better picture tomorrow if you like.
#1069
I just ran out and looked and I don't see a location on my cab that could take your routing.
#1070
#1072
So, I guess they stopped punching holes in the firewall for an obsolete heater after 1954.
As far as the routing of the wires, dealers installed the heaters many times so it may have been up to the installer where the wires entered the cab.
#1073
I guess they came out with the different heater in '54 for the extra control. The box heater I have does not allow for redirecting the airflow to the floor or windshield. What you got was what you got. Even the motor was a single speed. I have seen a couple with a variable resistor to control the fan speed, but none of them looked factory.
#1074
I was thinking... I could re-route my wire through that hole without taking out the heater again. I could cut the wires, drill a hole through the ABS and then put the wire through that hole and then splice the wire.
Then I would have to find some grommets to fill those holes. Any help Number Dummy for NOS grommets?
#1075
Things have gone a little slow. I got pissed with my wire connectors on the heater so I stopped on that for a minute. I then decided to change the front shackle pins and bushings. Well I fought with one bushing for the weekend off and on and gave up. I need to order the bushing removal tool I guess. Today I got to thinking I should just take it to the tire shop 1/2 mile from my house and have them press the bushings out. grrr....
Some good news. Sam has started working on the bed. He called today discussing the crossmembers. We are putting 4 in and the stake pockets don't allow for an even distance between them all. He has bent and welded in the stake pockets. We are going with standard 4" C channel. I was looking at thinner C channel, but that would have been a lot more expensive.
Here are the pictures he sent. I told him to take a bunch for my records and to share with you.
It will be a busy week and possibly a super fast trip to Nebraska this weekend for an indoor track meet. Man I need to not be so rushed sometime.
#1076
#1077
#1078
Yes, I'm always afraid of breaking things and I'm very good at procrastination.
Speaking of not being able to focus. Is there a benefit to using the 56 door latch instead of the 53-55? My drivers door won't shut and I need to replace it. If the 56 is better (and same price) would it be good to go that route?
Shoot, I have even looked at the Altman latches, but that's a bit dark side. See..no focus.
#1079
I'm excited that it is actually under way. It will make a huge difference in the truck when I have an actual bed on it. Knowing that my son built it will make the truck even more special.
It's really nothing with the heater wires. I just tried to crimp an end on one of them and it just wouldn't stay attached to the wire. I haven't been able to focus much lately, so it annoyed me pretty quickly and I walked off. Lately it seems that any simple job I do becomes difficult.
So yesterday I went to replace the striker plate. I looked in my stash of NOS striker plates. I couldn't find any fornthe drivers side. Then I remembered I replaced the striker plates on my 55 this fall. I have a big zip lock bag of 56 striker plates, numbering about 8. And there was only one for the drivers side.
I put it on and it works. I wanted to move the door back just a bit since it is very close to the cowl of the cab but I can't cause then the door would not the striker plate. But the important thing is that my door stays shut!
So to answer your question..... the 56 striker plate would give you more area of contact between the plate and the star latch. But you have less space to move your door front and back.
#1080
I wanted to tell you also that I stopped by the place in Lincoln to check on a rear view mirror. Unfortunately no luck. All his parts are in totes/boxes, in trailers that are outside. No lights, and the day I was there it was about 10 degrees. He wasn't very confident when we started digging. Sorry! He said he might have a couple of side windows. I figured it best if you stop by some time to verify quality. Plus I know you wanted to snoop at some point anyway Take care of yourself my friend.
