55 239 Y-Block Restoration Thread
#946
Thanks for the suggestions abe. I was wondering where I was going to get the rubber parts. I don't know why I didn't think to look at midfifty.
Steve, good suggestion. I need to grab a skinny glass and get it soaking. Although, the top part of the nut doesn't seem too round. That may make it more difficult. We will see.
#948
So I have my rebar and my Sodium carbonate. Is there a preferred gauge of wire connecting the rebar together? I would think the larger the wire the more current it can handle which would be better.
#949
I used the electrolysis on several of my parts. Worked pretty good but you need to use a gray scotchbrite on the part after your soaking is finished. Any solid copper wire works. I had some 12 gauge house wire that I just peeled the plastic off. Been thinking about trying it on a rusted cylinder head.
#950
Well, I've set up my electrolysis tank. Tomorrow when I get home from work, I will fill it with water and Sodium carbonate and get it going.
I used this thread as my main source, plus google "electrolysis rust removal" just to be extra sure.
https://www.ford-trucks.com/forums/1...t-removal.html
#951
#952
#953
Yep, I got the grill off. I figured I would put it in the bath together.
Man, your interior is beautiful. That reminds me, I need to get the firewall cover as well. I like that rubber mat as well.
Dang, my MidFifty wish list is up to $1000. It's mostly rubber. I guess the window anti rattle kit is $200....And the firewall cover is almost that.
On the electroylsis, how much hydrogen will this make? I was thinking of keeping the tub in my garage. I can open the side door and put a fan on it. I would rather not have it outside, but if need be I can put it just outside the garage side door.
Shoot, gotta pick up some scotchbrite today as well.
#954
Are you getting the ABS firewall cover with the sound deadening matting behind it? That's what I got and it makes a world of difference in sound and engine heat. And now is the time to put it in before you put your heater back in.
#958
#959
Try that argument with your wife and let me know how it goes.
I filled up the tank this evening and hooked up my battery charger. After a couple of minutes, it didn't look like anything was really happening. A sticker on the charger mentioned that power would only be at the terminals when hooked to a battery, so I figured it wasn't reading things right and didn't power on.
So.....Of to my in-laws to steal an old school charger. I Ford one at that.
After a couple of hours, this is what the tank looks like. I pulled out the part and I think I will pull it out and scrub it before I go to bed and it will probably be good.
This process seems pretty slick. I wish I would have tried it sooner on some of my parts.
#960
That seemed to go well. It was in the tank for about 3 hours.
Before:
After:
I cleaned of a lot of the black with a scotchbrite. Should I put it back in the bath for a while, or is that about as far as it will get? There doesn't seem to be any rust, just black coloring.
Is there a point where you need to add more sodium carbonate to the water, or will it last until you decide the water is mucky enough and needs new solution?
Before:
After:
