55 239 Y-Block Restoration Thread - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 03-31-2012, 10:49 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Set the points at .014-.016 for a 272. I would think a 239 will be quite happy at those settings. Point gap is not something that has to be dead accurate to get her fired up. Sometimes it is easier to get that big old socket wrench on the crank pulley to bring it up to top of the distributor cam lobe. Good luck, we're waiting to hear her run.
  #62
Old 03-31-2012, 11:03 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Wayne, awesome info. Now I have another tool I have an excuse to buy.
To follow up.
Here is a thread on hooking up a dwell: http://www.ford-trucks.com/forums/94...o-hook-up.html
Here are the distributor settings from the 54-55 Shop Manual:
Hopefully I will get a chance to try some of this out tomorrow.
  #63
Old 03-31-2012, 11:09 PM
Harrier's Avatar
Quote:
Yeah, I grabbed the socket today to be able to watch the points move easier.
Every time I try to start her up, I have my son hold the video camera. I have a bunch of short videos of frustration.
I will post that video as soon as it happens, after I stop bouncing off the walls.
This engine has been quiet for 40 years...man I was just 3 or 4 when it last ran.
  #64
Old 04-12-2012, 05:17 PM
Harrier's Avatar
I haven't had a chance to spend any time in the garage lately, but i think I have the points set correctly. I will want to double check.
As I was putting the distributor cap back on I noticed the rotor is a bit loose. Should it be on there tight or have some play?
Here is a video of how much play it has.
Y-Block Rotor - YouTube
  #65
Old 04-12-2012, 06:58 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
There should be no play between the rotor and the distributor shaft .
  #66
Old 04-12-2012, 08:30 PM
Harrier's Avatar
Quote:
I thought so, I wonder if I have a wrong rotor....I bought it many years ago before my daughter was born. I didn't see any type of screw to hold it in place.
  #67
Old 04-12-2012, 09:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Are you sure you aren't just moving the advance mechanism? is the distributor cam turning, too?
Some rotors have a little metal clip in the bore where they push on, to lock it to the flat on the dizzy shaft. Make sure that isn't missing.
  #68
Old 04-12-2012, 10:35 PM
Harrier's Avatar
Quote:
Well that may be it. There is a recessed band on the dizzy shaft that meets up with the base of the rotor when you put it on. I'm guessing there should be some clip that goes in there to hold it steady.
I love pictures so this might explain.
The red box on the dizzy matches up with the red box on the rotor. Notice the 'notch' not sure what else to call it. It looks like the perfect place for a clip. Now the NAPA photos of the part doesn't show any clip that comes with the rotor though....
  #69
Old 04-13-2012, 10:18 AM
raytasch's Avatar
There should be a clip at the end of the shaft and it does fit into the recess of the shaft. But, this is not what is keeping your truck from running. As a temp repair when the clip was broken or missing, I've taken a piece of heavy paper stock and wedged it between the shaft and rotor. I am talking about the Ford tractors, that use a similar clip, but the paper would work on the truck. Again, the missing clip is not preventing the truck from starting but it will prevent the truck from running well.
  #70
Old 04-14-2012, 01:16 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
The tractor and car / truck clips are a different part number. Dennis Carpenter has the car / truck clips; I just purchased several since all the flatheads I get seem to be missing that dang clip.
  #71
Old 04-24-2012, 11:19 PM
Harrier's Avatar
How do Points work
Well, I haven't had time to spend on my truck for the past couple of weeks. Track season has me all over the place, Middle School and High School track with Wednesday night baseball as well....
I have been pondering my points and trying to better understand their operation so I can more effectively troubleshoot my problem.
Be sure to correct me if I'm wrong and I will edit this post so I have it straight and anyone else that finds this thread looking for answers will be on the right track.
Let's start with the picture:
Here is how I see the function.
The battery goes to the + wire of the coil and the -wire goes to #1 in the drawing. When the points are closed it completes the ground and the charges the primary. When the points open, it breaks the ground and that powers the secondary and sends spark.
Simple enough. In the drawing, 1 Neg Coil is wired directly to 1B. Between 2 and 3 is where the ground is interrupted. 3 and 4A are connect via the points. 4A and 4B are connected by a wire. 4B is the ground point to the engine. Notice that 4B is pointing to a screw that attaches a wire to the dizzy base.
So, since I have spark at the coil my problem is confined to 1) bad plugs 2) bad wires 3) bad distributor cap 4) bad points 5) bad connections in 1 through 4 in the picture.
Let's focus on 4 and 5. The wires under the spark advance are very old, is there a place to get those or do I just get plain wire and replace? If I do that, are there tricks to removing the spark advance?
OK I really think the problem is at 4) bad points. If I put an ohm meter at any point between 1 and 4B I should get little to no resistance when the points are closed, correct? Currently I get that for the most part, except for between 2 and 3 in the drawing. When points are closed I get an open circuit. I would think that would indicate I have a problem with the points. This seems odd since they are basically new. I bought them about 10 years ago when I was planning on just getting the engine running (and before baby #3)
What do you guys think?
  #72
Old 04-25-2012, 07:55 AM
raytasch's Avatar
I really don't have time to read and understand what you are saying this am. A couple things, though. The wire that runs from the coil to the points is available at NAPA, I just replaced mine within the last six months. You'll have to find a guy who understands what you need. Called the primary wire. Check the ground wire also when you replace the primary. If the primary wire is shorted, insulation missing, you will not run. Check the points, make sure they're opening. I'll check this later.
luck.
It does appear that you have a point problem. The only time you should have a circuit thru the points is when they're closed. It is not uncommon for points to get an insulating coating, oxidation, when they're not used. I have run into this on tractors that sit unused. Sometimes running a dollar bill between the points will break the oxidation to where they'll conduct. A very fine grit paper or point file may be required to break the film.
To test: Have power to the primary wire and turn engine to close points. Use an insulated tool to open and close the movable point arm. You should see a spark at the points if they are working.
  #73
Old 04-25-2012, 10:04 PM
Harrier's Avatar
Thanks Ray, I will try that. I figured that there was a problem there. It threw me since the points have never really been used, but they have been sitting there for a long time. Looking closely at the wires under the spark advance, I really need to replace those as well. Might as well get that done while I'm in there.
Now, when will I get a chance to do that....kids are keeping me busy, but it is time I wouldn't miss for the world.
  #74
Old 04-29-2012, 08:39 PM
Harrier's Avatar
Well, I got some sandpaper and cleaned the points. Well that sure helped with the resistance. I didn't think of them getting corroded since they were sitting together for several years. I had stolen my father-in-laws battery off his Allis, but I had to return that the other day. I'm too tired this evening to pull the battery out of my truck. So, since he moved the Allis, I think I can steal the battery back for a little bit, tomorrow.
At least I'm getting closer. I don't have any track, baseball or massage Monday evening, so I'm hoping to spend a little time in the garage.
  #75
Old 04-30-2012, 12:07 AM
chavez626 chavez626 is offline
chavez626 is starting off with a positive reputation.
i bought this same engine a few weeks ago from a guy that had it on a 55 f100 and now i am going to put it on my 53 f100 and i need the crossmembers for the engine and tranny????any place i can buy them or any place i can buy parts for this enfine 239 y block
1977 F250 Supercab restomod project Crash F250 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-17-2016 11:59 AM
239 Y-Block Water Pump on ebay Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-27-2016 07:56 AM
7.3L IDI in '66 F250 Chris Hawkins Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 07-29-2015 06:25 PM
Jeff City, MO Car Show July 2013 Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 07-29-2013 10:16 AM
Broken Hose and Degraded Hose ID GP-TJ 1997-2006 Expedition & Navigator 4 11-26-2011 08:43 PM
Tags
1955, 239, 55, block, daytona, diagram, duplicolor, engine, f100, firing, ford, motor, order, paint, picture, v8, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
