55 239 Y-Block Restoration Thread
Old 02-29-2012, 06:13 AM
Harrier's Avatar
Harrier
Harrier is online now
Flybear2000, I would love to get the measurements for you. I won't be home much for the next couple of days, but I will get a bunch of pictures taken with lots of measurement as soon as I can.
By the way, welcome to FTE. We would love to see pictures of your truck. Start another thread and let us see what you have. We love pictures.
  #47
Old 02-29-2012, 08:03 AM
Flybear2000's Avatar
Flybear2000
Flybear2000 is offline
Upcoming Pics
I noticed that on this site. I will be uploading some very soon, just need some time to get better pictures than what I have so far. The only thing I have done to this truck since we bought it is work on it, and the only pictures I have are the pics of when I removed the radiator to replace it and discovered the cross member issue. Thanks for the welcome, take care and thanks for getting the measurements for me, will be looking forward to having some information I can work with.
Michael F. "BEAR" Cooper
Flybear2000
  #48
Old 03-02-2012, 06:19 AM
Harrier's Avatar
Harrier
I'm wanting to make sure my spark plug wires are in the correct location and after hunting for a while I found this from "Ford Y-Block" by James Eickman:
This may be common knowledge to some, but I'm sure there are others like me who aren't quite so versed.
  #49
Old 03-02-2012, 05:23 PM
Harrier's Avatar
Harrier
Well now I'm a little confused. Here is the wiring diagram. Notice that it looks like that cylinder 1 is closest to the driver.....what's up? I would think the schematic would be more accurate since it came out of the Ford Manual but a schematic doesn't necessarily show exact placement....What do you experts think?
  #50
Old 03-02-2012, 05:58 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Forget that pictorial so far as cylinder numbering. Number one cylinder is the front on the passenger side and runs 1-2-3-4 front to back on the passenger side. Going to the driver side we have 5-6-7-8 front to back. Cylinder number are on the intake manifold runners near that feed the cylinders on the 272-312 CID engines. Firing order is 1-5-4-8-6-3-7-2 on the engines I mention and I would suspect the 239 Y block is the same.
  #51
Old 03-03-2012, 06:43 AM
Harrier's Avatar
Harrier
I feel like I'm asking a bunch of dumb questions here but how else is one to learn.
Years ago when I was looking at just getting the engine running I replaced the distributor cap and spark plug wires. Well, I replaced them exactly as they were on the old distributor cap and actually labeled them. This was before I knew the cylinder numbering. I seemed to have lost my notes on how I numbered the cylinders so I don't know for sure if I have the wires on the correct side. I do I confirm which wire goes to which cylinder?
  #52
Old 03-03-2012, 07:11 AM
raytasch's Avatar
raytasch
Believe Nothing
The number 1 location should be marked on the distributor cap and should be pointed toward the firewall of the truck as the engine is installed. Insert the wire to number one plug therein and route the wire to the front plug on the passenger side which is number 1. The internals of the distributor rotates CCW so the wire to the second cylinder in the firing order goes into that hole to the left on number 1. Follow the distributor cap holes CCW with the wires to the plugs in the firing order, number five. Follow the holes, insert wires and continue with the known firing order and plug placement.
  #53
Old 03-03-2012, 07:40 AM
Harrier's Avatar
Harrier
Ray you are a lifesaver.... Well, I just ran out real quick and couldn't find any markings on the distributor cap. I pulled a couple of wires in the location you suggested but didn't see anything. The cap only goes on one way...
I just looked at the wiring diagram and it looks to be accurate if the distributor rotates clockwise not CCW....
  #54
Old 03-03-2012, 12:56 PM
Gregruk's Avatar
Gregruk
Gregruk is offline
Firing order markings and pot numbers should be on the manifold , see pic of mine !
Cheers
Greg
  #55
Old 03-03-2012, 09:18 PM
Harrier's Avatar
Harrier
Very interesting Greg, my intake doesn't have the cylinder numbers.
I wonder if they added this later years since my 239 is the first year of the Y-Block.
I think I figured out my spark plug wire numbering. My new starter is working great. Now I have to get spark to the plugs.
Any tips on wiring the coil and testing spark for a newbie? It should be just wire the positive to the battery and ground the negative to the block, correct?...by the way, I'm converting to 12V negative ground.
  #56
Old 03-31-2012, 09:38 AM
wrmckay's Avatar
wrmckay
wrmckay is offline
Numbers
I'm restoring a 1956 F-250. Was noticing your engine numbers, and wondered what resources you're using to figure out what they mean?
  #57
Old 03-31-2012, 05:36 PM
Flybear2000
I just want to add my two cents worth, whenever you are working on any vehicle, just remember that when you are looking at diagrams like this they always orientate them left and right as you sit in the drivers seat, example cylinders 1234 are on passenger side as you sit facing forward from drivers seat, and 5678 are on drivers side as you site in drivers seat. They did it this way to keep from getting confused as to what side you are talking about when describing a vehicle issue. It is done the same way with planes and in the military. Just watch out, sometimes when describing engine banks they switch and go as if facing the front of engines with newer cars, comes from sales people and techs not being taught correctly.
  #58
Old 03-31-2012, 07:52 PM
Harrier's Avatar
Harrier
I dig all over the internet.
I get so much information from asking questions here.
If you have a Y-block a good book is "Ford Y-Block How to Repair and Rebuild the 1954-62 Ford OHV V-8" by James Eickman
Here is a great site Earl's world with lots of good info: http://www.clubfte.com/users/earl/index.html
Get yourself a shop manual. Here is a link to one on Amazon: Amazon.com: 1956 FORD PICKUP TRUCK Shop Service Repair Manual Book: Automotive
I highly recommend this book. 1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage It's the best $22 you will spend.
This site has some good info, scoll down to the bottom for technical info: FORD Y
There are no dumb questions around here. If you have never done it before, you can't know the answer with research and asking the experts. Experts abound here and they are more than willing to help the inexperienced guys like me.
By the way, if you show pictures of your truck everyone will love you more.
Start up a thread and ask away.
  #59
Old 03-31-2012, 08:21 PM
Harrier's Avatar
Harrier
I haven't had much time to work on things the last week or two. My oldest two are in track and one is in baseball as well, so I've been running all over.
I got a new coil and it seems to be working fine. I finally pulled my head out of my tail and pulled the distributor cap and saw that the points don't seem to be opening when the engine spins. I'm starting to research on how to properly set these, but if you guys have quick tips I would appreciate it.
Here are my points:
Looking at the picture I noticed more. I should just be able to use the screw at 12 O'Clock and adjust them there, correct?
Now, should I get them on the high spot of the distributor and adjust the gap there?
Hey wrmckay; these are the kind of questions I'm talking about. I'm sure tons of guys here are saying.."Well, duh! " but they are always polite to guys like me.
  #60
Old 03-31-2012, 09:40 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,438 Likes on 1,390 Posts
Originally Posted by Harrier
Here are my points:
Yes and yes. Bump the engine over until the point rub block is on the high side of one of the cam lobes on the dist shaft. Barely loosen both screws, the top one is to lock down the adjustment, the lower one will allow the points to move. You want to leave them snug enough to hold a set while you adjust. There should be a little notch near the adjust screw where you can put a screwdriver in the slot to help make the adjustment. Set your gap using a feeler gauge. Check your manual for specs. Once you have the points where you want it, tighten the screws, check the gap once more to make sure nothing moved, then put the cap and rotor back on and fire it up. If you have a dwell meter, you can double check your work. Checking the dwell is the correct way to set points. The feeler gauge get you in the ballpark. In theory, if the gap is perfect, the dwell will be right on. The real world isn't always that exact.
It's been a lot of years since I've set points, I hope I did it right.
Quick Reply: 55 239 Y-Block Restoration Thread
