55 239 Y-Block Restoration Thread - Page 38 - Ford Truck Enthusiasts Forums
  #556
Old 09-02-2014, 09:45 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Quote:
Originally Posted by 38 coupe View Post
Getting a 12V generator for you truck should be really easy, any 1956 or later Ford generator will be 12V. Most will bolt right onto a Y-block. That said, unless you are adding A/C, I see no need to switch to 12V. 6V is easier on a restoration since you don't have to worry about compatibility with your temp, oil pressure, and gas gauge.
Oh, so now you are going to make me use logic and figure out what is really best for me in my situation. Now that it is crunch time, I need to take a step back and analyze what I really need.
So here are some notes to myself, I welcome feedback and direction:
Truck plans:
This will be a basic truck to be used as a truck but not a daily driver.
No AC or Stereo. Very little night driving.
I want to get it up and going for as little money as possible but still is safe and reliable.
12v
Parts I have
o Battery
o Coil
o Solenoid
Parts I need
o 12v generator ~$100 from O'Reilly
o Voltage reducers for gauges ~$60
o 12v voltage regulator $60
6v
Parts I have
o 6v Coil (Not 100% sure it's good) $25
o 6v Generator
o 6v voltage regulator (I've got 2, one NOS)
Parts I need
o 6v solenoid $17
o 6v Battery $100
o Anything else?
I will need wiring, battery cables, bulbs, gas tank sending unit, anything else? for both.
Looking at pros and cons:
12V easier cranking, brighter headlights,??
6V Stock, looks to be cheaper in my case, ??
Based on this analysis, it looks like 6V is probably the way to go.
Didn't AXRacer post a dissertation on planning your trucks future.....which I copied and saved. I guess I should follow folks advice sometime
Please correct anything that I got wrong. This is a very helpful exercise for me. Now for the parade, I'm staying with my 12v battery and coil. That works for my short stints until I start the wiring process.
  #557
Old 09-03-2014, 05:24 PM
Harrier's Avatar
Well I went out and had a couple of cables made today. DANG! 00 copper is $12 a foot. It was a bit more than I expected, but if you look at the ones I had, I'm ashamed to admit I had it on the vehicle until today.
I will need to save up for the battery cables. But I'm currently running 12 volts, so I'm good with my regular cables for now.
  #558
Old 09-03-2014, 05:30 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Funny how bad 60 year old cables can get! Money well spent.
  #559
Old 09-03-2014, 08:20 PM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Well, Joe, it looks like you decided on staying 6 volt. Good choice from the way I see it. Those new cables will help a lot. You said 12 volt has easier cranking. Not exactly true. The 6 volt will crank just as fast but the downside is it won't crank as long as a 12 battery. Shop around for your 6 volt battery. I think $100 is high. Do you have an auto electric shop near you or an ag store that sells batteries for old tractors?
  #560
Old 09-03-2014, 10:14 PM
Harrier's Avatar
BJ, yeah I'm happy with the cables. I'm cheap, but doing it right is important.
Abe, thanks for that info. I'm not experienced with 6V systems. I will be looking around for the right battery. It will be the balance between a good one and a cost effective one.
Interesting thing happened today. I spend time out in the garage and actually accomplished a few things.
Cables are installed, timing is set. I still need to tighten that bolt more, dang it's hard with the cab on. I even bought a distributor wrench, cheap thing that didn't work for me. I need to find a stubby wrench.
I also got the inner fenders on.
It's amazing what you can get done when you actually go out to the garage.
I will try to meet up with a guy about rims on Saturday. He has 4 outies and he is asking $60 for all four. Unfortunately he removed the tires which were tons better than the ones I have. I have 3 innies nice and painted now. Maybe one day I will find another innie. Shoot for that price, I don't think I can go wrong.
  #561
Old 09-04-2014, 07:41 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
$15 per wheel is hard to beat.
  #562
Old 09-07-2014, 02:06 PM
Harrier's Avatar
Well, it's been a pretty productive week. Lots of little things.
Solenoid is back on the firewall
New starter cables installed
Heater valve replaced
Steering column mount cleaned and re-installed
Instrument cluster re-installed
Speedometer cable installed
Acquired new rims and have cleaned and painted the two I will use.
I have the transmission cover back in place but not set in.
Here are some pictures.
I can't wait to change that from all zeros. Also to see the speedometer work.
The new one is not built near as nice. Notice how on the old one you can get a wrench above the inlet. The new one is harder to tighten down with your carb on.
It's awful dark with those black inner fenders. You can see it much better in person.
I'm dropping the rims off tomorrow after work and they will put new tires on them Tuesday. I will get some pictures of them later.
  #563
Old 09-07-2014, 03:11 PM
U B kicking some serious B#~t on getting ready for the parade! What kind of tires are you installing? Bias or radials?
  #564
Old 09-07-2014, 04:20 PM
Harrier's Avatar
Quote:
I'm going with radials. 235/85-16 (I think that's the size)
Here are my 4 rims I will be using. Notice two are innies and two are outies. I decided to do this instead of the 4 outies all the way, just to keep more originals, well and the fact that the innies were already clean. My two split ring rims are outies, so it will be the same as when I got it. Also I have some innie hubcaps....
The newer rims are slightly wider, but that should be noticeable to anyone.
I will now have 1 innie rim, 2 outies, and 2 split ring rims laying around as extras.
Here are the rims:
I also just got done with some Simple Green and water on my grill.
I removed the V8 emblem and I will clean up that bracket and look to put the grill on. I also hosed off the lower valance. I noticed the rubber was stapled on???
  #565
Old 09-07-2014, 04:24 PM
Harrier's Avatar
My plan is to take it out next Saturday and drive it around for a while and let it run for an hour or so. I will probably hook up the trailer and pull that around a bit. I know I have a ball somewhere.....
  #566
Old 09-07-2014, 04:38 PM
Quote:
Staples, tacks and hog rings held a lot of the front end rubber in place
  #567
Old 09-09-2014, 08:34 PM
Harrier's Avatar
OK you enablers! Now what do I do with these?
I've got 4 new tires on the truck!
Here is comparison of 7.5X16 to 235/85-16
Here is how they look on the front:
I'm a little worried if I can let enough air out of the tires to get it low enough to fit through the garage. As a last resort, I might have to build some wheeled cart to rest the front end on and remove the tires to lower it enough. I guess I will find out Saturday morning.
  #568
Old 09-09-2014, 08:43 PM
Harrier's Avatar
Now for another question.
I'm not sure I have the transmission cover setup correctly. There is a ring on the shaft under the cover sitting on the transmission and it is loose. There is also a gap.
Here is what it looks like now, it's a little hard to see with all the black:
You can kind of see what it was originally like in these pictures. In the picture with the cover removed you can see the ring barely and it is encased in grease and dirt.
Could there have been a boot at sometime there? It's pretty open for the emergency brake lever. Maybe you just expected that openness. But, The ring just seems odd. I don't see a purpose for it. After I read stories to my youngest I will see if I can find it in the book to know what to call it.
  #569
Old 09-09-2014, 09:22 PM
Harrier's Avatar
Here is a picture of that ring. I couldn't find it in the parts catalog.
It fits like it belongs but it isn't fastened down. The parts catalog didn't show any boot for the shift lever either.
  #570
Old 09-10-2014, 05:32 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Yep, that is the ring that just lays there. I believe it had a rubber seal bonded to it at one time.
Exhaust Thermostat on my 239 Y-Block??? Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-17-2014 06:08 AM
Should I put the body on and go or fix dents and such first? Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 01-29-2014 09:45 PM
Y-Block Lower Pulley removal Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 02-05-2012 02:47 PM
Y-block oil pump cleaning Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 01-04-2012 09:03 AM
56 F350 With Wood Bed Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 07-09-2011 10:07 PM
Tags
1955, 239, 55, block, daytona, diagram, duplicolor, engine, f100, firing, ford, motor, order, paint, picture, v8, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
