55 239 Y-Block Restoration Thread
Old 08-18-2014, 04:46 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
So I'll have to find another place if I come back to help?
  #512
Old 08-18-2014, 05:10 PM
Harrier's Avatar
Harrier
Harrier is offline
Don't worry. I will give good directions.
  #513
Old 08-19-2014, 06:28 PM
Harrier's Avatar
Harrier
Harrier is offline
Well, I just couldn't do it!
I have...had the front sheet metal on and was ready to bolt it down more. Last night, I decided to clean up some fender supports. They came out nice:
But, looking at the inner fenders and the hood locking panel, I just couldn't let them stay all rusty like that. So, I removed them this evening and will clean and paint them hopefully this weekend.
Here are some before pictures.
Hopefully I will have them all clean before the end of the weekend.
  #514
Old 08-19-2014, 06:33 PM
bjmayberry2
I agree! They'll look much better cleaned up. We just ran out of time. Were you able to find more nuts and bolts? Put flat washers on the bolts along the fenders.
  #515
Old 08-19-2014, 08:49 PM
Harrier's Avatar
Harrier
Harrier is offline
I haven't gone to look yet. I will try Ace Hardware tomorrow. I know they have the fine thread, it would be nice if they had the proper heads though. Yep, flat washers. Got quite a few. I will go to Orschlen's to get more since they sell by the pound. Too bad they don't sell fine thread by the pound.
Gotta get a new wire cup for my angle grinder too. It's a little worn down now.
  #516
Old 08-19-2014, 08:59 PM
blue_cloud's Avatar
blue_cloud
blue_cloud is offline
Be careful! Around here bolts by the pound are Grade 2, here in PA it is not legal to use anything less than a Grade 5 bolt for motor vehicle applications.
I'm not clear if that applies to body panels however. I never buy anything less than a grade 5 to have on hand at the shop. If I have a specific project that a grade 2 will do, I just purchase what I need.
  #517
Old 08-19-2014, 09:12 PM
Harrier's Avatar
Harrier
Harrier is offline
Missouri sells grade 5 by the pound, I'm pretty sure.... But, I haven't bought any for a little while. I will double check just to be sure. I definitely don't want grade 2 on my truck.
  #518
Old 08-19-2014, 09:55 PM
bjmayberry2
I can only find Grade 8 UNF bolts at our farm stores. They are sold by the pound.
I did some research on the web and found a place that sells the original body bolts with the taper on the end. Classic Car Restoration Fasteners, Harley Davidson Chrome bolts, plastic auto clips, Virginia page 25 of their catalog. 5/16-24x3/4" or 5/16-24x1" but they are a buck apiece. Not sure what MidFiftys sells them for.
  #519
Old 08-20-2014, 09:09 AM
bjmayberry2
MidFifty seems to be the cheapest. $22.50 plus shipping for it looks like 24 nuts, lock washers and bolts. 1953-56 Ford F-100 Front Fender & Valance Top Bolts Black
  #520
Old 08-20-2014, 05:10 PM
Harrier's Avatar
Harrier
Harrier is offline
I went to Lowe's and they had a coarse thread bolt of this type, but they wanted $1.39 each!!! Coarse thread won't work anyway.
I considered using the coarse bolts I have, but for $22.50 I will be better off with the fine thread body bolts.
Now on the flip side, Lowe's had the 1/4 - 28 bolts for my hood latch parts for $0.56 for a pack of 4. Same for nuts. Now that was a deal! Ace Hardware had them for $0.39 each!
School board meeting tonight, so I won't be able to get dirty. Saturday sure changed my progress and attitude. THANKS!
  #521
Old 08-20-2014, 06:36 PM
bjmayberry2
Yes a little progress does tend to give you a second wind!
  #522
Old 08-24-2014, 10:27 AM
Harrier's Avatar
Harrier
Harrier is offline
Well, I got my upper valance cleaned painted and installed this weekend. I started on the inner fenders. Dang, I'm looking into finding someone to sand blast some parts. The wire brush on the grinder moves so slow, and the paint and rust stripper pad for the grinder works well, but you go through it so fast. I will probably be better off with the sand blasting.
Look at my poor frame all dirty. I need to give her a sponge bath.
  #523
Old 08-24-2014, 11:08 AM
bjmayberry2
Lookin Good!
  #524
Old 08-24-2014, 05:43 PM
Harrier's Avatar
Harrier
Harrier is offline
Well, I decided to take a break from grinding and did a basic cleaning of the instrument cluster. It cleaned up pretty good with only two cuts on my fingers.
Before:
After:
I will do more work on it, but this will hold it for now.
  #525
Old 08-24-2014, 08:41 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,615 Likes on 1,456 Posts
Before:
After:
Joe, here are some tips:
Get some red hobby paint. Put some paper underneath the needles and with a fine brush give the needle one brushstroke of paint. They do sell red paint that has some radioactive particles in it so they show up better at night... but I just used my wife's paint. Take it apart so you can start on the needle where you won't see it.
Sand your trim ring and paint it argent. There is a paint made by duplicolor that matches the silver used by Ford quite well.
I put some Armor All on a soft rag and wiped the black part of the panel. It brightens it up. Be careful not to get it on the white numbers as they can smear a bit.
If your rubber gasket is shot underneath the glass, go to the hardware store and buy some weather stripping of the same thickness. Do have the glass in in that after pic? If so it cleaned up nice, if not go to the hardware store and have them cut you a piece of single strength glass.
Quick Reply: 55 239 Y-Block Restoration Thread
