55 239 Y-Block Restoration Thread
#211
Harrier, I understand that 239 accessories were painted black and rocker covers Argent. So, I think that your color scheme is (close to) period correct.
I'll re-hash seal measurements that I just took:
NOS B6C-8591-A: seal ID 0.625" (bushing), OD 1.877"
Aftermarket? B5A-8591-C, labelled "BB473" on flap: seal ID 0.625", OD 1.440"
Measured w/calipers, close enough for government work.
I just looked at the book and here is what it has. It looks like the smaller seal was used for a lot of pumps and in 56 they started with the larger one.
That is probably why mine was easy to rebuild. The kit may not be available, but the parts separately are standard.
#212
Interesting that I measured two significantly different ODs. May be in where/how they were measured. Anyway, one's notably larger. Sad, I received one with a chip on the seal surface. The molded plastic seal carriers won't readily interchange. One has three notches and the other has four. Other than that, the ceramic seal surfaces themselves are effectively identical.
If you ever use a rotating ceramic seal, it must be absolutely clean for longest life. No oil, not even fingerprint oil, is the way to install them.
Last edited by The Horvaths; 08-06-2013 at 10:04 PM. Reason: Going over drawings and bill of material all day. Rampant typos.
#213
You seem pretty excited and I completely understand. I look forward tosome pics. Mine is a 55 239 yblock so I am definitely interested in info on the guy that built it. Just in case.
OK, I just realized I am way behind... dang phones fault
Last edited by tnguynaford; 08-06-2013 at 11:56 PM. Reason: comment was on post 2 pages back
#214
J & I Automotive Distributors
1624 State Highway A
Marshfield, MO
800-468-2448
I got the water pump back today. Woo Hoo!!!. Whatever he used to clean it up, I want some of that.
My water inlet tube got a little smashed. It was in iffy shape to begin with. I know Mac's has one.
It looks like he did some welding or something on the impeller. The picture isn't that great of the back.
I reviewed the how to properly color a Y-Block thread, and although there is no real consensus, I think I'm going with yellow for the pump. The pulleys and other attachments were black but all the old photos show the water pump yellow.
#217
on
But then I don't have a little woman anymore either.
Can't imagine why. Ya should see what I do to the wash machine.
Then again maybe ya don't. It ain't pretty.
#218
Have you got a water shut off on your water pump to your heater core? Mine looks like at one time it had a handle of some sort on it but no more. I've been tying to find one but can't seem to locate one. I'd post a picture but it just looks like an elbow (90 degree).
I saw a picture one FTE just recently that someone had a ball valve inline for a shutoff. I think it was on the heater hose...
#221
MACs has the nipple & gasket for the waterpump bypass. I see in your pics yours is like mine corroded after 55 plus years
1948-79 Late-Ford-Pickup Truck Cooling System - MAC's Antique Auto Parts
#222
I guess I'm hoping the parts will magically appear in one catalog.
#223
Well, I was painting my water pump and since I got the clutch shoulder bolt and spacer spring, I decided to put that all together. Well low and behold, some idiot put my rear brake frame bracket in that bag. When I looked several times, I thought it was my clutch return spring bracket. But that one is still attached to the suspension bumper in that bag. Cool...now I need to go buy some break line and start running them.
I will get a picture of the newly painted pump when it's back where it belongs. Good start to the weekend.
#224
I have not read through this whole tread,So maybe it has all ready been brought up. I see you have used a copper gas line,My understanding is this could be a problem. It is my understanding that copper will become brittle, and could break, when used as gas line.I would hate to see your good work go up in flames. Maybe someone with better information could help. Sorry if this has been addressed.
#225
