55 239 Y-Block Restoration Thread
#166
Joe, the replacement primary wire is the longer one, varying lengths. The insulated through the housing terminal you show is replaced and the primary wire runs all the way from the points to the coil. Not a perfect restoration but it eliminates one connection. The new primary wire may have to be shaved and or sealed with a dab of silicon where it runs through the housing. Napa has the replacement wire, may have to special order it. Do not use a regular heavy conductor wire as it must flex a lot.
Edit: I hope someone proves me wrong and the original type is still available for you restoration guys.
#168
#169
on
Wow. I just found this thread, or found it again, I am not sure.
Your doing great. I just luv me a Y-Block.
One thing that I am thinking about is still the timing.
You moved the wires around the cap until ya got it to run.
But did you recheck the timing marks on the front of the engine at TDC in comparison to number #1 on the cap?. I ask this because if the timing chain
slipped than the thing ya do is move the wires around the cap until it runs
enough to get ya home.
With only 30k on It I hope this ain't what has happened.
I hope this makes since as it is late for me and meds are working great.
#170
Arctic, My problem was that I wasn't smart enough to realize that the timing mark hits twice. So my plug wires were 180 degrees off. Also my cap doesn't have a #1 marked on it anywhere. The timing chain looked good and hadn't slipped.
When I get the radiator hooked up (Should be soon.) I will spend some more time on it and make sure it is running smoothly.
#172
#173
That number matches my book.....
#174
Well since my wire looked pretty good. I just made a washer to replace the one that was falling apart. I actually just made one from radiator hose material. After doing that and getting my timing set better, it started up and ran fine. It even was pumping a little oil up to the rockers for the short run I did. About the time I shut the engine off, my 8 year old opened the garage door and commented how Mom didn't want the house smelling like gas...then Mom followed up with more of the same. "Why don't you roll it outside to do that?" "Well because you wanted the cab off your side of the garage and I can't roll it out with the cab on it..." I saw Ray's one many cab removal system and it is much more efficient than mine, so I will do that...
Now for the bad news.....
I went to put on the generator bracket and as I was tightening one of the bolts, it broke off. <insert your favorite cuss word here> Also, I have a little leak in the water pump. There is a small hole at the bottom section. It looks like it is supposed to be there. Well when I remove that and the timing cover to get the bolt part out, I will take a picture and show you what I have.
Also, what is the best way to remove that piece of bolt? It is probably less then 1/2 an inch of thread in the block. (We will see when I dig into it.) I don't have a bolt extractor tool, so if I need to buy one, suggestions on something fairly cheap that will do the job would be helpful. Grrrr....
No telling when I will get out to the garage to start on that. Kids baseball tends to take up a lot of time. It seems I only get 15 -20 minutes at a time in the garage when I do. My ADHD, no money and no clue all contribute as well.
Did I mention my son got hit by a pitch on April 19th and broke his maxilla? (The upper bone holding the teeth in) ER, Dentist, and Orthodontist bills so far. Maybe a root canal in the future as well....The joys of parenthood. By the way, he was back playing a week later. (One tough kid) It happened on a Friday, Monday the Dentist said he could play if he had a mask protecting his mouth. He said: "So technically I can play on Tuesday." We told him no baseball while taking pain meds. He went to Aleve that day. Good thing Tuesday got rained out.....
#176
I would love to have you come over and visit. Having someone experienced just looking over what I have and giving me some tips and pointers would be wonderful. We will need to work out a time that I'm not running all over the place. I can put some brats and burgers on the grill and we can eat and you can teach me all sorts of stuff. That invitation goes out to anyone interested in traveling to scenic California MO, and willing to impart some knowledge.
#177
Hey gang, I discovered my water pump had a leak. I talked to my uncle who owns an independent auto parts store, and he mentioned that I'm screwed. He doesn't have one, but he gave me a place that can rebuild them. I will call them this evening, but here is my question. Napa says they have it for sale.
NAPA AUTO PARTS
Do you think this would actually work for my truck. It's the high van mount and has the same number that my uncles books had (58-233) But the heater hose output looks to be on the wrong side...No, it's got both. Well maybe it will fit...any thoughts? They are asking $86. I called a local machine shop and they would ship my existing one out to get rebuilt. He guessed that it would cost about $110.
I guess it wouldn't hurt to get one in and see....I'm surprised they would have one though. Am I getting lucky?
NAPA AUTO PARTS
#178
