87 door panels on a 92 door?
Old 02-13-2012, 09:45 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
Bootlegger's Deluxe is offline
im putting together a 1992 F250 that came to me with no door panels. the doors are crank window, manual locks. I have an 87 that i'm parting out that has an XLT interior package, but also was crank window/manual lock. Will the door panels swap on and work properly?
I'm afraid trying to find a set of XLT door panels with the crank windows and manual locks in red will be difficult in the 92-96 bodystyle ..
Old 02-13-2012, 09:53 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
As far as I could tell the doors themselves are the same from '87-'97 but, the part of the door panel that meets the dash if shaped differently. might have a clearance issue with the dash.
Diesel Rod
Old 02-13-2012, 09:54 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
Pretty sure they will work. The doors didn't really change during those years so I don't see any reason they wouldn't work. Wouldn't really match with the dash though.
I think PW/PL were standard on 92-96 XLT, so you would need to look for XL panels.
Old 02-13-2012, 10:25 PM
Bootlegger's Deluxe
I really like the bottom map pockets on the xlt door packages tho ...
Old 02-13-2012, 11:22 PM
donnor's Avatar
donnor
donnor is offline
Slim & trim...
If both trucks are manual windows & locks the panels should be a direct swap. If they were power units then some wiring changes would be necessary.
dn.
Joshs 93
07-06-2016 08:21 PM
ojh
02-27-2014 02:20 PM
68fordf100v8
02-09-2013 08:01 PM
TheKirbyMan
03-19-2010 05:03 PM
Jud75
07-23-2004 10:13 PM
Quick Reply: 87 door panels on a 92 door?
