Headers ???? - Ford Truck Enthusiasts Forums
Headers ????
Old 02-13-2012, 01:27 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Headers ????
Does anyone know of some headers that will fit in a '58 with a 351 W? I am not looking to spend more that $200 on a pair. I have already bought/returned 3 sets in the last year, none of which fit correctly.
Thanks for the input.
Old 02-15-2012, 11:11 AM
blackedout blackedout is offline
blackedout is starting off with a positive reputation.
Which sets did you buy? I don't want to do the same.
Old 02-19-2012, 04:51 PM
fast58's Avatar
I bought some Hedman long tube headers. I was able to get a refund on those. I also bought some polished stainless steel shorty headers from ebay. They bolted to the motor but the flange had the steering box under it where I couldn't put exhaust pipe on it. I also bought some others from a friend that do fit. They are long tube and I don't know what brand they are. The thing about them is that the bend of the header is so tight that it touches the spark plug wire boot and melts it. I am at my wits end with headers.
Old 02-19-2012, 09:25 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
You may have to compromise on that 200.00 limit.One thing that may work is trying a set of plug wires that have boots/connectors that can be bent 45 degrees or so.Otherwise,buying a set of header flanges and having tubes custom bent may be your only other option.Doubt that can be done for 200.00.Someone who has a Fridge with a 351 may come along and give another solution.I had a set of Sanderson headers,which I believe to be of the highest quality available,on my Y-block,before switching to Ramhorn manifolds.Try their site?
Old 02-20-2012, 05:01 AM
walkee's Avatar
walkee walkee is offline
walkee is starting off with a positive reputation.
Im running Sanderson FC3 headers in my `60 with a 400. The 351M/400 should be similar in size to your 351W.
Good fit, good quality, no clearance issues on starter, steering and frame.
Old 02-23-2012, 12:43 AM
fast58's Avatar
Sanderson seems to be relatively expensive. I have a set of headers now that would work if the driver's side was bent about two inches more, but then the header would hit the block. I'm about to give in and do manifolds but I hate to have spent so much money on building the motor and using stock manifolds.
Old 02-23-2012, 12:47 AM
fast58's Avatar
After looking at the Sanderson FC3 headers I'm thinking I may save up for them and hope they fit. $345 ain't too bad for fitting headers.
Old 02-23-2012, 12:59 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
The headers you got from Ebay may work now that the original steering box is no longer in the truck.
Old 02-24-2012, 07:09 PM
fast58's Avatar
Because I wanted to use the original column I had to do some bracket work. Now the bracket I made takes up just as much room as the original steering box. So it's five steps forward and two steps back. I tried bending the bracket out some but it turns out welded steel is pretty strong, even when cherry red.
Old 02-25-2012, 07:29 PM
fast58's Avatar
The search for headers ended today. I finally found some that fit. They are from Speedway Motors. They are labeled as Small Block Ford tight fit headers. There is plenty of clearance on both sides. And they only cost $169 unpainted. Much better than $345 for the unpainted Sanderson headers. I painted mine with high heat black paint and they look great.
Just thought I would tell everybody about some headers that will fit and doesn't break the bank.
Old 02-25-2012, 07:33 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
How close are they to the starter?
Old 02-26-2012, 12:32 AM
fast58's Avatar
Not at all. I would guess 6-8" in front of the starter. They come almost straight down instead of pointed to the rear. I will have to take a couple of pictures to show ya'll.
Old 06-27-2012, 11:31 AM
Bought the speedway headers and they hit my starter. BUt just barely I might be able to grind the flange enough to fit the starter in anyway.
Old 06-27-2012, 06:12 PM
Hmmmm I just Swapped sides with the headers and that way does not hit the starter... Maybe that's what fast58 did.
Old 07-09-2012, 01:04 PM
New starter fixed the issue, but still tight on the motor mounts. Also my steering is not going to be pretty. Gonna ship these back and try some shorty mustangs with the dumps facing back.
Seems like I'm talking to myself.
Speed Daddy Stainless headers for a 351w choate 1987 - 1996 F150 & Larger F-Series Trucks 42 10-04-2016 01:35 PM
Header recommendaton? peakster 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 12-27-2014 11:52 AM
headers 351m highboy f250 3/4 1977 KSun90 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-31-2013 08:24 PM
Gibson or Bassani headers? (351w) fordmarshall111 Exhaust Systems 3 01-26-2004 12:31 PM
351W 5.8L Shorty Headers Brizzadd Exhaust Systems 11 08-01-2003 04:33 PM
Tags
1957, 1959, 2007, 28, block, explorer, f100, ford, headers, hearers, small, trucks, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
