What U-joint for rear driveshaft?
Old 02-13-2012, 12:24 PM
NW 150's Avatar
NW 150
NW 150 is offline
Should I use? 75 f100, 9" rear. Just wondering what you guys recommend for u-joints. I'm lookin around at autozone advance auto napa and oreillys. I don't want on that will wear out in 5 months like that one that I put on there last year.
Old 02-13-2012, 04:35 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
Spicer is what I used last time, from NAPA. Always have done OK.
Old 02-13-2012, 04:47 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
Spicer....will cost more but will hold up better.
Old 02-13-2012, 05:29 PM
Deluxetruck's Avatar
Deluxetruck
Deluxetruck is offline
Spicer if you can get em locally, or else neapco makes a nice joint as well. Anything made in the USA will be leaps and bounds ahead of china stuff.
Old 02-13-2012, 09:06 PM
NW 150's Avatar
NW 150
NW 150 is offline
there's nothing showing up for spicer at napa. Are the duralast golds at autozone china? What about these?NAPA AUTO PARTS)
Old 02-20-2012, 10:36 AM
speedyweasel's Avatar
speedyweasel
speedyweasel is offline
I have a Duralast Gold on my rear diff. It's garbage. No zerk fitting and it's made in Ch1n4. Get Spicers and don't let them sell you on the supposed lifetime warranty on the Duralast... turns out it's a lifetime warranty - ONCE. You blow it up once, they replace it once. Then you buy another "lifetime" warranted junk joint. Just go Spicer and don't look back.
Old 02-20-2012, 12:09 PM
Behemoth's Avatar
Behemoth
Behemoth is offline
I've got Spicer 1350 series (part number 5-178x) joints on my rear driveline, but I also had to have a custom driveline made in the first place. Since I was adding the Gear Vendors overdrive unit on the back of my transfer case, I eliminated the two-piece driveline, and had a beefier one piece unit built. Since I had to do that, better U joints were in order as well. The upside is that it eliminated three potential failure points (two u joints and the carrier bearing).
burnthelight88
01-30-2018 11:40 AM
elkarcher1716
05-03-2013 09:17 PM
green_6
Bronco II
09-11-2003 09:49 AM
kburch
Bronco II
11-08-2001 07:15 PM
nitro94
05-06-2000 10:56 PM
Quick Reply: What U-joint for rear driveshaft?
