???? 1988 ford f350 4x2 to 4x4 can i do it????
Received 3,090 Likes
on
on
you'll be time and money ahead to count your losses of making the mistake of buying the 2wd truck when you needed a 4wd.if you payed fair for it,you should be able to sell,save and buy a 4wd.this conversion is not for the faint of heart.its a mod only worth doing to the F-Super duty (pre f450) imho.anything else is worth buying the 4wd for starters.i guess the light duty f150's everything is pretty much bolt on swap.not the case with the hd 250/350's.
i wouldn't want to be be fdude this month lol. dude,your going to be saying some new words,you didn't even know you knew pretty soon here.
It can be done, but dont know if YOU can do it.
What year is your donor? It will make things easier if it is a 91 and older.
You need...
front and rear driveshaft
4wd transmission(from a 460 ONLY)
transfer case
front axle with matching gear ratio to your rear axle OR both axles from donor
rear f350 block
Front springs
front spring hangers
front shock brackets and shocks
track bar mount and track bar
driverside u-bolt plate
You need...
transfer case
rear f350 block
Front springs
