tow mirror question
tow mirror question
Hey guys i have been thinking about changing out my tow mirrors for the ones with the parking / blinker on them but my mirrors now have around plug and the other ones have a rectangle plug. I wanted to see if its possible to put the other mirrors on without butchering the wiring.
Thanks,
-AJ
Thanks,
-AJ
I would love to know what that Ford part # is too! I've had a set of these mirrors hanging around for a while now because I too was afraid to butcher up the OEM wiring. I went to my Ford dealer a while ago and they were no help. They said no such wire conversion connector existed from Ford.
As far as the wiring, its really easy. From the factory Ford has the heat wired to come on with accessory power. I mimicked this by taping into the power for the windows. Other than that you only have to run the wires for the running lights (I ran my to the headlight switch) and the blinkers (mine went to the steering column).
I found these on fte.
Right hand side 1C3Z 14A411 AA
Left hand side 1C3Z 14A411 BA
Its the adapters for round to rectangle.
How hard is it to run the wiring to your sterring column? Im pretty **** about my truck and want everything to bejust right. And if you tap into the headlight switch you wont run the risk of overloading the factory airing or anything right? Sorry for the stupid questions just wanting to make sure before i do anything.
And you wont overload anything in the process.
New Mirror installation
Heres a site i stumbled on. Its a pretty good write up but i do have a question about the wiring near the brake pedal that he writes about towards the end. On an 01 does anyone know the wire colors for signal and park lights? That would be easier then running to the column
I dont know relays and stuff... I just left mine always powered. If thats how ford did it, its good enough for me.
The wiring is pretty simple to do. I tapped into the front turn signal wires right behind each signal assembly. Spliced and soldered the wires, then put them in a loom to each mirror.
I tapped into the parking lamp circuit on the brown unused wire on the factory trailer brake harness.
I added a switch to my switch box for the mirror heat.
jeffdoerr
02-15-2006 04:40 PM
JoeBoost
1999 to 2016 Super Duty
12-31-2003 01:05 PM
