Engine Size - Ford Truck Enthusiasts Forums
Engine Size
Old 02-12-2012, 06:09 PM
midsouth midsouth is offline
midsouth is starting off with a positive reputation.
Engine Size
How do I determine what size the engine is in my 1983 ford f150 4X4? Is there any information stamped on the truck. I do know that it is eight cylinders simply looking at the distributor cap.
Old 02-12-2012, 06:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Are any of the emissions or information stickers still on the rad support, or under the hood? They will say.
If it's a V8, it's either going to be a 302 (5.0L) or 351 (5.8L).
Old 02-12-2012, 06:18 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
Post the 8th digit of your vin. That will tell you at least what engine your truck was born with.
Old 02-12-2012, 06:19 PM
Thank you. I'll take a look.
Old 02-12-2012, 06:36 PM
81ChopTop's Avatar
81ChopTop 81ChopTop is offline
81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.
A real quick reference is to measure across the intake. A 302 will be 7 1/2", a 351 will be 9". I visually do that at the scrapyards because you never know what's been done.
Old 02-12-2012, 08:32 PM
Greyf100's Avatar
Greyf100 Greyf100 is offline
Greyf100 is gaining momentum as a positive member of FTE.
or just post up a pic, most that have dealt with the trucks long enough can tell you by intake design / dimensions and / or valve cover bolt pattern.
2005 Ford Excursion 4x4 For Sale rlauer Vehicles for Sale 1 07-31-2015 08:38 PM
60,000 transmission fluid change? awq134 2009 - 2014 F150 6 12-25-2014 02:50 PM
2001 F-350 4x4 Front Clunk Over Sharp Bumps bumpdraft 1999 to 2016 Super Duty 23 12-02-2014 12:01 PM
Clicking heard in carb greenmachine55 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-12-2014 05:25 PM
Do I need THREE Negative cables on a '79 F150 battery cable clamp? ScullyisaFox 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-29-2011 11:39 PM
Tags
engine, ford, size, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
