Transfer case and Royal Purple Questin - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 02-12-2012, 05:56 PM
Fuha's Avatar
Fuha Fuha is offline
Fuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputation
Went out today and did my weekly under inspection under the vehicle.. Looks like the transfer case is leaking oil. According to the chart I will post in a bit it says use "XL-12, ESP-M2C166-H, Transfer case fluid". I want to drain and refill the case with what I know is in it not what someone has told me is in it. What do you recommend for it?
Royal Purple... They are a sponser of the bass tournament series that I fish. IF I buy there product and finish in top if i sign up for there program they cut me a check for 25k. That would be enough for my second X. However, part of it is I have to buy there product. Well, this year they have changed there product line and opened it up to all there products instead of just 2-cycle oil. What do you think about there product, Motor oil, lubes, gear oil?
Fluid Chart I Was using : http://www.fcsdchemicalsandlubricant...f/axlelube.pdf
Old 02-12-2012, 06:44 PM
ddivinia ddivinia is offline
ddivinia is gaining momentum as a positive member of FTE.ddivinia is gaining momentum as a positive member of FTE.
A lot of people use it around here. I don't have any experience with it.
D.
Old 02-12-2012, 07:24 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Have only heard good things about Royal Purple. Have it in my wife's RX300 transfer case and rear end. Will be putting it in her transmission soon too. If you have a transfer case leak and you put in full synthetic, I have heard (not sure if it's true) the leak may get a little worse because the synthetic is so pure. I plan to convert the Ex to all Royal Purple in the driveline as the existing fluids age out. I just don't plan on using their motor oil.
If you have a chance for a sponsor reward, GO FOR IT!
Old 02-15-2012, 09:08 PM
Fuha's Avatar
OK so an update pin pointed my leak today its were the transfer case and tranny come together. Transmission was rebuilt in November so I am calling the tranny shop to get then to fix this. As this is somethung they touched when they put everything back together. I let ya know what they say when I get off the phone with them in the morning
Old 02-15-2012, 09:45 PM
Rosson03's Avatar
Rosson03 Rosson03 is offline
Rosson03 is gaining momentum as a positive member of FTE.Rosson03 is gaining momentum as a positive member of FTE.
Royal Purple!!!!!!!!
i like royal purple. i have used it for a while now in all my fluids. for using it so much i have found out tricks how to get it cheaper too. u see what u can get it for then i will see what i can get it for.
this goes for anyone also
Old 02-15-2012, 10:41 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
It's awesome stuff that works well, you'll pay a little more for it, but it's worth it.
Old 02-16-2012, 08:36 AM
fishintheobx's Avatar
fishintheobx fishintheobx is offline
fishintheobx has a good reputation on FTE.fishintheobx has a good reputation on FTE.fishintheobx has a good reputation on FTE.
Royal Purple ATF overall is good stuff. Suitable for the transfer case, but they recently changed their formula and it wouldn't be my first choice for a transmission.
Good to see them sponsoring fishing given how their marine products have taken off. I ran their FC-W rated oil in my F200 Yamaha outboards. After 100 hours the oil analysis numbers on the FC-W Royal Purple and Amsoil blew away the synthetic Yamalube.
Old 02-16-2012, 09:34 AM
Fuha's Avatar
Quote:
I heard nothing but good things about there boat oils. I havnt ran it personally through the last few years on this tour as I dont use enough oil to justify buying $100 dollars of it a year.
Talked to the tranny shop this morning it has an appointment monday morning to go see them to get this fixed under warranty.
Old 02-16-2012, 10:27 AM
Quote:
I hear ya... Sometimes I think my Outboards are in a race with my 6.0 to see who can have the most expensive oil change. But moisture is a killer when these things sit, and the FC-W spec is supposed to combat that. A friend of mine is a Yamaha mechanic with a 3 week wait-list to see him. And when I found out what he charges for a rebuild I decided I'd be buying the best on the market. I have one engine pushing 1800 hrs, and the last compression test indicated it was experiencing no issues.
Twisted axle rlpatte 1999 to 2016 Super Duty 55 03-27-2015 11:45 AM
F150 5.4L V8 vs. F250 5.4L V8 digruk Modular V8 (4.6L, 5.4L) 11 02-26-2015 09:20 PM
No injector buzz when key is turned on? reptyls 6.0L Power Stroke Diesel 2 01-25-2015 07:35 PM
Need help, several codes! daddyzhome 3.8 & 4.2L V6 6 12-07-2014 06:44 PM
v10 oil leak wahfulls Modular V10 (6.8l) 5 01-13-2013 12:49 AM
Tags
06, 302, 60, amsoil, case, excursion, f150, f250, fluid, ford, gear, motor, oil, powerestroke, purple, royal, transfer, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
