Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 02-12-2012, 10:49 AM
snelldawg's Avatar
snelldawg snelldawg is offline
2012 Ford F-350
snelldawg is starting off with a positive reputation.
If I was a fog light wiring harness, where would I be?
2012 F350 XLT
Supposedly they come prewired from the factory (the XL's do not)
I looked behind the spot where the for lights would be installed, and I don't see anything. Are they located somewhere else? Any help would be appreciated. Thanks
__________________
2012 F350 XLT 6.2L CC LB FX4: Line-x, Bilstein 5100 shocks and stabilizer, OEM 20" wheels, Recon smoked cab and mirror lights
2005 F250 CC King Ranch (Gone but not forgotten)
"It's better to have too much and not need it than not have enough"
  #2 (permalink)
Old 02-12-2012, 01:20 PM
snelldawg's Avatar
2012 Ford F-350
I was able to find them based on this info from LEADSLED56 in another thread, I assumed that they would be closer to where the lights are located:
I found the truck's wiring harness ready to go right underneath the radiator support/frame crossmember, mounted to the frame with a block-off cap over the connector. I removed the cap and plugged in the fog light wiring the kit came with, strung the wires over the top of each frame rail, plugged them in and tested the lights. everything worked correctly so I proceeded to attach all the little plastic plugs where I could find holes in sheet metal. the first one I started with was at the connector on the radiator support. then I just worked my way to each light. done and done.
__________________
  #3 (permalink)
Old 02-12-2012, 02:06 PM
biz4two's Avatar
biz4two biz4two is offline
Garage is empty, add now
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Good to know! Thanks for posting...
OBTW: Should share some pics of before and after...
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #4 (permalink)
Old 02-13-2012, 06:55 AM
fg250's Avatar
fg250 fg250 is offline
2012 Ford F-250
fg250 is starting off with a positive reputation.
Quote:
Originally Posted by snelldawg View Post
2012 F350 XLT
the xl has the wires also.
  #5 (permalink)
Old 02-13-2012, 07:27 AM
snelldawg's Avatar
2012 Ford F-350
There seems to be a difference between XLT and XL. When I looked on Ebay they had packages for XLT's that were less money than Xl's, and they clearly said that there was a difference. (MSRP is $215 for XLT parts)
Also, my dealer told me that if it was an XL, there would be another hour or two of labor involved.
__________________
  #6 (permalink)
Old 02-13-2012, 09:53 AM
Powerdude Powerdude is offline
Powerdude is starting off with a positive reputation.
I hate the fact that you have to get the XLT value package, at $1395 MSRP, just to get fog lights on your brand new truck.
This is ridiculous. I don't want the stupid SYNC system or for that matter steering wheel radio controls or the keypad entry thing.
Just more electronic crapola that is already obsolete anyway, for the SYNC, and more holes in the steering wheel and the door that can break down.
  #7 (permalink)
Old 02-13-2012, 10:24 AM
fg250's Avatar
2012 Ford F-250
the difference is that the XL kit comes with a new BCM. The XLT already has the correct BCM to run the foglights, and the XL does not. The extra labor is replacing the BCM and reprogramming it to the truck.
P.S. (BCM=body control module)
  #8 (permalink)
Old 02-13-2012, 10:26 AM
fg250's Avatar
2012 Ford F-250
I couldn't agree more. That's part of the reason I went with an XL and added the lights....much cheaper.
  #9 (permalink)
Old 02-13-2012, 11:07 AM
snelldawg's Avatar
2012 Ford F-350
Powerdude,
I agree with you 100%. I ordered my truck and was frustrated that I couldn't add just the lights. I didn't want the keypad and a couple of the other things for $1300.
Install seems straight forward, I might even do it myself:
1 Remove the bumper brackets from both ends of the front bumper... (heavy steel brackets with four bolts each)...
2 Remove the OEM plastic covers that are installed where the new fog lights will be installed...
3 Assemble the new fog lights as shown in the instruction page that comes with the kit...
4 Install the complete kits in the right and left side...
5 Reinstall the bumper brackets and tighten to factory torque specs...
6 Install wiring loop and plug the ends into the fog lights... The kit includes the wiring loop AND the plastic wiring keepers that simply plug into existing holes in the bumper frame...
7 Open the drivers door and... On the left side of the dash (drivers side) the end panel will simply pull away from the dash at the rear and swing out to expose the inside of the dash. Reach into this area and depress the tabs on the existing light switch (you will see them on the new one). This will allow the switch housing to move out of the dash. Once the switch housing is out of the dash, unplug the switch and plug the new switch in. Then push the new switch into the hole in the dash, replace the dash end panel... and you have installed the components that YOU can install so far...
8 These steps should be completed by some one who knows a bit more about the insides of the dash... Install the light sensor that is provided in the kit... It mounts in the center of the dash in a hole that is close to the bottom of the windshield and directly under the rear view mirror.
9 Install and program the new Body Control Module per FOMOCO instructions.
Note: If you bought a truck that came equipped with the Automatic Headlights... Steps 8 and 9 are NOT necessary.
__________________
  #10 (permalink)
Old 02-13-2012, 12:12 PM
fg250's Avatar
2012 Ford F-250
Powerdude,
Actually you're a little off hear....the light sensor is easy to install with a small flat screwdriver the cover for that hole pops out. (anyone can do it) also the BCM is easy to change out.....HOWEVER the truck wont start until you have a Ford mechanic with the Ford computer do the reprogramming....I had a friend of mine who works at my local dealer come over after work with the dealers computer and do it. (I found all this out the hard way) also, step 9 is not neccesary with an XLT, peroid, regardless of auto/non lights. only XL trucks have to go through that.
  #11 (permalink)
Old 02-13-2012, 02:26 PM
snelldawg's Avatar
2012 Ford F-350
I found those directions online. The basics for me will work since I'm sticking with conventional and I do not have to reflash.
__________________
  #12 (permalink)
Old 02-13-2012, 02:40 PM
fg250's Avatar
2012 Ford F-250
yep, the directions that come with the kit are pretty close to what you posted, but they are a bit decieving. They never actually tell you that if you change out the BCM nothing will work until you take it to a dealer. It's kinda BS, I think. But for you with an XLT and no autolamp, it's a piece of cake.
  #13 (permalink)
Old 02-29-2012, 06:39 PM
Longliner Longliner is offline
2012 Ford F-250
Longliner is starting off with a positive reputation.
XL With FOGS and whats necessary
Guys,
i just installed fog lamps on my XL. From what I can gather if you have the Power Equipment Group (or maybe XL Decor) the BCM is already ready for fog lamps.
I have an XL with Power Equipment Group and XL Decor and all I needed to do was install the fogs and the switch. So, I could have saved myself about $115 dollars by ordering the XLT fog package (and would have got the ambient light sensor to boot).
In short, BCM is not needed in some cases on the XL.
Anybody want to buy a BCM ?
Thanks.
  #14 (permalink)
Old 02-29-2012, 07:09 PM
fg250's Avatar
2012 Ford F-250
[quote=Longliner;11509015]Guys,
that's interesting, because i also have the power equipment group, and decor. I still needed the BCM.
Tags
2011, adding, bcm, connector, duty, edge, fog, ford, harness, light, lights, super, wire, wiring, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
