6.2L V8 Discuss the 6.2L V8
10,000 GVWR rating
Old 02-15-2012, 10:54 AM
superfast bob's Avatar
superfast bob
superfast bob is offline
10,000 GVWR rating
Hi all; ready to pull the trigger on a SRW F350 KR gas but need to do the 10K option to save money on insurance. Really don't need to pull heavy.
My question, I was recently told this 10K GVWR truck is "different" than the 13K rated truck. Salesman says smaller radiator and trans cooler???? Never heard of this, anyone have any insight? thanks.
Old 02-15-2012, 11:12 AM
snelldawg's Avatar
snelldawg
snelldawg is offline
Sounds like BS to me.
I have the 10k package, I thought the only difference was the springs for the 10k versus the heavy duty suspension package (13k). The sticker is a DOT rating.
Old 02-16-2012, 03:50 PM
superfast bob
snelldawg; yes I thought the only difference was just a DOT sticker with no other change to the truck. I guess no one really know's.....
Old 02-16-2012, 07:38 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
There's no difference according to the order guide. You just get a sticker saying 10k. I think the springs are even the same.
From the '12 order guide:
10,000 GVWR PACKAGE (68 D)
Availability:
• Optional on F-250/F-350 SRW
Includes:
• 9,900 lbs. Gross Vehicle Weight Rating (F-250)
• 10,000 lbs. Gross Vehicle Weight Rating (F-350 SRW)
Old 02-16-2012, 10:44 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
^^^ what he said ^^^
Sometimes...it would really be nice that a sales person actually know the product they sell. OMG...that is criminal...IMHO.
biz
Old 02-17-2012, 06:37 PM
jmiley's Avatar
jmiley
jmiley is offline
My truck has the 10,000 GVWR, how is that supposed to benefit me?
Old 02-17-2012, 06:53 PM
snelldawg's Avatar
snelldawg
It depends on your state's registration and inspection rules....it might or might not help you out. Insurance could also be a factor.
Old 02-17-2012, 07:31 PM
jmiley's Avatar
jmiley
jmiley is offline
Registration is based on the curb weight of the vehicle, mine weighs about 6500 lbs, and is about $180 a year for the registration.
I will check with my insurance agent about it.
Thanks
Old 02-18-2012, 12:20 AM
n3hcp's Avatar
n3hcp
n3hcp is offline
Here in PA truck weight class is based on GVRW. 10,000 is class 4A and costs $198 per year. 13,000 is class 5 and costs $243.
Old 02-18-2012, 04:14 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Here in Comi land a new F350 will run you over $600.00 a year to register. Heck my 76 F250 still runs $212.00!
Old 02-24-2012, 12:15 PM
Powelligator's Avatar
Powelligator
Powelligator is offline
The 10,000 GVWR option is there primarily to reduce the tax & registration burden to a purchaser who rarely uses the truck to its fullest rated capacity. It's the current follow-on to the "HD" designation given to a lot of F-250's back in the '90's where the truck had "one-ton" rated springs and suspension yet was officially rated as a 3/4-ton. So far, so good, right? Well, there's a trade-off…
Let's say that you have a single rear wheel F-350 optioned all the way out with every extra payload package the computer selects. Let's assume the truck weighs 7,000 pounds. Your cargo is a 3,500 pound slide-in camper. At 10,500 pounds you're below the rated capacity of the truck and all should be well. But if we add the 10,000 GVWR option then you are *technically* 500 pounds over the rated capacity of the truck. The truck can handle this load no problem, but it's not *rated* for it. Where this becomes a problem is if, God forbid, you end up in an accident with the truck which is no fault of your own and during the investigation it is found that you are over the rated capacity of the truck. It *could* be argued (in a court of law) that by being overweight you might be partially at fault for damages.
For the record I'm in favor of the 10K rating (if in your jurisdiction that's an advantage) but I just wanted to present the potential ramifications.
Joe
Old 02-24-2012, 11:46 PM
Powerdude's Avatar
Powerdude
Powerdude is offline
It actually raises the GVWR of F250's, but lowers that of some F350's.
Go figure. Yes, you will save money on insurance and registration in states that do their fees by GVWR.
As for being sued for causing an accident, that is true.
You can also be sued for farting in a public place, and causing a panic in a movie theater by throwing popcorn.
Anybody can sue anybody for anything, it's just a question of how much money it will cost you to win (or lose).
Old 02-25-2012, 09:07 AM
jmiley's Avatar
jmiley
jmiley is offline
Joe
On the F250 the GVWR is 9,900 lbs, the 10,000 GVWR is an option.
On a F350 SRW you can get a GVWR of 9,900 up to 11,500 lbs.
On a F350 DRW you can get a GVWR of up to 13,300 lbs
When loading a vehicle you need to take into account not just the weight of the slide in camper used in your example, but all of the rest of the stuff that goes inside it as well as the people and stuff being carried inside the cab, plus the fuel in the truck.
Old 02-25-2012, 03:02 PM
Onus's Avatar
Onus
Onus is offline
If anyone is from Connecticut. A gvwr over 10k will make you exempt from emissions testing.
Old 02-28-2012, 06:08 PM
snakebit's Avatar
snakebit
snakebit is offline
I have a '12 350 6.2 on order. Order sheet says #11300 GVW.
What gives in the order/spec book on the difference in HP and torque between the #10,000 and other trucks?
J.
Quick Reply: 10,000 GVWR rating
