leveling kit question - Ford Truck Enthusiasts Forums
Old 02-12-2012, 10:11 AM
guitarist41991's Avatar
guitarist41991 guitarist41991 is offline
guitarist41991 is starting off with a positive reputation.
im looking at ordering a leveling kit this week for my 95 f150 4x4. i was looking on broncograveyard.com and they have one kit for a reg cab and one for a supercab. why would the supercab coil springs be different than the reg. cab ones? the reason im asking is because one kit is BDS and the other kit is Superlift. i dont really know which brand is better so i figured id ask the experts. heres the links below:
1.5 - 2 inch F150 Supercab 4WD Leveling Kit
BDS 1.5" - 2" Leveling Kit
Old 02-12-2012, 12:42 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
I bought mine off eBay and they said not for supercabs. When I asked why they said the springs are a little different in diameter.
I called a couple parts stores and the ford dealer and they list the same spring for the reg can long box as the supercab shortbox. So I got them anyway and they fit good
Old 02-12-2012, 12:44 PM
Mine were spacers not springs, my bad. But the same thought might be there
Old 02-12-2012, 06:36 PM
alright thanks. does anyone know if i will need longer shocks in the front? bronco graveyard has some for a 1.5" lift on closeout right now for $18
Old 02-12-2012, 07:31 PM
I re used my stock ones as they were only 2 months old, but I'd yours are older the. It might not hurt to get the longer ones. Especially at $18/ea
Old 02-12-2012, 08:14 PM
yea thats what im thinkin. mine are the original shocks and the truck has 117,000 miles on it so ill probably order 2. i would order 4 because my truck has factory quad shocks up front but the ones that are on clearance are only for the front of the front axle. thanks for your input!
Old 02-12-2012, 10:15 PM
tommytwotone86's Avatar
tommytwotone86 tommytwotone86 is offline
tommytwotone86 is starting off with a positive reputation.
even though you buy the longer springs your gonna be in the same boat im in with the crooked tires.
Old 02-12-2012, 10:49 PM
Quote:
You and me both lol , just waiting for some extra $ to get an allignment before the tires go on
Old 02-13-2012, 01:48 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I'm going to probably be getting the Superlift ones again. Its my understanding that the BDS have the same specs as the Superlift. An extended cab truck weighs more than a regular cab. Superlift also makes then for regular cab. Bronco Graveyard doesn't list the Superlift regular cab ones.
You don't need different shocks. Years ago I had longer shocks with leveling springs. I swear they were almost too long.
Old 02-13-2012, 10:16 AM
alright, ill keep that in mind. i just got a quote from a local tire/4x4 shop on an alignment and the guy told me that it would be around $45 so that dont sound too bad to me. ill probably order the kit today or tommorow.
Old 02-13-2012, 01:20 PM
got the BDS kit ordered today so ill know in a few weeks how it rides
Old 02-14-2012, 10:44 AM
That's cool. Do post back after you get it. Don't forget pics.
Old 02-14-2012, 11:29 AM
$45 to set the toe, if they have to change the camber bushings which they most likley will It should be more then $45 I was quoted around $200
Old 02-14-2012, 12:28 PM
ill get some before and after pictures up when its finished. hopefully ill be able to get the bushings in myself but this shop lifts alot of trucks so id think that they would be able to do everything correctly. hopefully it wont cost $200 cause thats a little more than i wanna pay.
Old 02-15-2012, 07:42 PM
Got my BDS leveling kit in from broncograveyard.com tonight. super fast shipping!!
Looking for suggestions for lift springs NW 150 Offroad & 4x4 42 11-17-2012 07:42 PM
Different Windshield Seals? FX5 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-01-2012 01:33 PM
1-2" coil springs MUDBUCKET 1978 - 1996 Big Bronco 3 02-08-2012 09:55 PM
leveling springs octaneforce 1987 - 1996 F150 & Larger F-Series Trucks 18 01-26-2012 05:11 PM
witch coil spring out of these two? mbxmitch Offroad & 4x4 6 12-20-2011 08:19 PM
Tags
1050, 2, 2in, 2wd, 32x1150s, 33, 95, 96, bushing, camber, excursion, f150, ford, kit, leveling, questionsford, r15
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
