leveling kit question - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-28-2013, 06:04 PM
13nparthemore's Avatar
13nparthemore 13nparthemore is offline
13nparthemore is starting off with a positive reputation.
Personally i think it looks good the way it is. Maybe a roll bar with lights on? Ive always liked roll bars on short box trucks
  #62
Old 02-28-2013, 06:21 PM
mikerans mikerans is offline
mikerans is starting off with a positive reputation.
my truck has about a 4 inch rake...i was thinking, could i use f250 springs of the same year, and 2 inch spacers in the font??? iv read other people using f250 springs...but theres so many... variable rate, supercab,w/o or with a/c..which would i use for a 95 f150 4x4 reg cab 8 foot box??
  #63
Old 02-28-2013, 06:25 PM
Ive read in diff forums that none of that stuff really matters like a/c or ext cab. I just got 1.5" rough country leveling springs. Cheap and fast shipping!
http://www.topguncustomz.com/p-9392-...-lift-kit.aspx
  #64
Old 02-28-2013, 06:31 PM
guitarist41991's Avatar
guitarist41991 guitarist41991 is offline
guitarist41991 is starting off with a positive reputation.
Quote:
i doubt you could do both because you wouldnt be able to align it properly. but if your truck has that much rake, the springs are probably slap worn out and a 2" leveling kit should fix it. maybe someone else will chime in.
  #65
Old 02-28-2013, 06:46 PM
well im pretty sure the guy before me put a add a leaf on the back, because he towed a lot of real heavy stuff. and i replaced both springs and shocks about 2 years ago. and im afraid if i do just the spacers that it wont be enough. and i don't want to get 4 inch lift coils because it might be to much. and from what i understand is that f250 springs aren't exactly taller, but they're stiffer so when if installed, instead of losing a half inch or so, id keep it because it wouldn't drop as much, so that along with a 2 inch spacer should give me a visual combined about 3 inches, which would be perfect. also im aware il have to buy new bushings for adjustment.
  #66
Old 05-20-2013, 08:36 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
I'm note sure If I put together this chart or if I saw it posted by someone else on this forum a few years ago. I thought I would post this here as a reference for springs lengths before and after installation. Of course this assumes the springs are used with the correct truck with correct motor. Putting springs into a lighter truck will yield a longer installed length.
<table border="1"><tr><td>F150</td><td>installed</td><td>load</td><td>rate</td><td>free length</td></tr><tr><td>CC818</td><td>12.13"</td><td>1258</td><td>337</td><td>15.75"</td></tr><tr><td>CC820</td><td>12.13"</td><td>1428</td><td>366</td><td>16.19"</td></tr><tr><td>CC822</td><td>13.00"</td><td>1430</td><td>366</td><td>16.38"</td></tr><tr><td>CC824</td><td>13.00"</td><td>1442</td><td>366</td><td>16.94"</td></tr></table>
<table border="1"><tr><td>F250</td><td>installed</td><td>load</td><td>rate</td><td>free length</td></tr><tr><td>CC820</td><td>12.13"</td><td>1428</td><td>366</td><td>16.19"</td></tr><tr><td>CC822</td><td>13.00"</td><td>1430</td><td>366</td><td>16.38"</td></tr><tr><td>CC824</td><td>13.00"</td><td>1442</td><td>366</td><td>16.94"</td></tr><tr><td>CC844</td><td>12.75"</td><td>1557</td><td>630</td><td>15.40"</td></tr><tr><td>CC844S</td><td>13.00"</td><td>759</td><td>629</td><td>15.79"</td></tr></table>
<table border="1"><tr><td>F350</td><td>installed</td><td>load</td><td>rate</td><td>free length</td></tr><tr><td>CC844</td><td>12.75"</td><td>1557</td><td>630</td><td>15.40"</td></tr><tr><td>CC844S</td><td>13.00"</td><td>1759</td><td>629</td><td>15.79"</td></tr></table>
<table border="1"><tr><td>BRONCO</td><td>installed</td><td>load</td><td>rate</td><td>free length</td></tr><tr><td>CC818</td><td>12.13"</td><td>1258</td><td>337</td><td>15.79"</td></tr><tr><td>CC820</td><td>12.13"</td><td>1428</td><td>366</td><td>16.19"</td></tr></table>
side tank sending unit V10man 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-27-2014 07:41 PM
Front coil spring pads NW 150 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-17-2013 02:07 PM
Looking for suggestions for lift springs NW 150 Offroad & 4x4 42 11-17-2012 06:42 PM
1986 f150 4x4 bds 2 inch leveling kit camo86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 05-24-2012 05:29 AM
leveling springs octaneforce 1987 - 1996 F150 & Larger F-Series Trucks 18 01-26-2012 04:11 PM
Tags
1050, 2, 2in, 2wd, 32x1150s, 33, 95, 96, bushing, camber, excursion, f150, ford, kit, leveling, questionsford, r15
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
